![]() | Home > Puma (Tdci) > Leaking windscreen |
have a look at link for defender leak fix from LRJ
https://1drv.ms/b/s!AtZSoWFHDgnGhERwdB-0XcdTS_UI |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
Yeah man, this is an issue here too, but only if I park with the right side lower than left.
Obvious solution is obvious ![]() Will sort proper if/when I repaint vehicle and install roll cage. Solved the bowel problem, working on the consonants... |
Harry.O Member Since: 25 Jul 2014 Location: Warwickshire Posts: 723 ![]() ![]() ![]() |
I ran a bead of Sikaflex along the foam seal and a bit behind the windscreen blocks for good measure. Don't use silicon because its a nightmare to paint over. That stopped most of it but discovered the windscreen seal itself was leaking, a small bottle of Captain Tolley's sorted it. It was a welcome fix having been driving in wellies previously
Dirt build up on the lower edge of the windscreen seal causes this leaking too, the dirt acts as a wick.
http://www.defender2.net/forum/topic2126.h...creen+seal If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
