Home > In Car Electronics > High Level LED brake light
Page 2 of 2 <12
Shax
England 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
I was planning on having them do a quick flashy flashy steady.. Just need to work out how to get a second feed up to the light assembly..
The electronicy side is easy, hiding the cabling is the real dark art!! ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
^^_-^-_^-^_^^^^^--^^^^
PAUL
G7ALW 14.200 USB
26FB458 / 27.275 SSB
Post #563703 13th Sep 2016 8:05pm
Feeding the wire up the door frame and out you'll have fun with. Razz
I'm assuming you are using the standard wiring rubber boot to gain entry to the door?
Post #563708 13th Sep 2016 8:19pm
Shax
Yeah, standard as far as I can go without drilling more holes.. ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #563761 13th Sep 2016 10:31pm
Defenders with 3rd brake light factory fitted have a hole up there with grommet in I'd imagine?
Needs a cable puller or a homemade type of puller to get it through.
Post #563781 13th Sep 2016 11:53pm
Shax
Nah... The feed is by the heated screen printed tracks... Wires exit the door at the bottom of the window... Sad ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #563980 14th Sep 2016 9:42pm
Alexke
Belgium
Just use
http://www.3rdbrakeflasher.com/brake-light...p-183.html
it also has a G-sensor. Discovery 4 SDV6 Landmark
F31 320dA Msport xDrive
LR Defender 90SW TD4 Stornoway grey
320d E46
E70 X5 3.0d Sold!
FFRR TD6 - Sold
Post #564083 15th Sep 2016 9:09am
Shax
Yeah, I could do that, but I where's the fun? I like messing with microcontrollers and accelerometers!
Smile ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #564370 15th Sep 2016 11:02pm
Shax
I aint forgot about finishing this post.. Just waiting on some fresh LEDS to turn up..
The last panel had me f*ck up, and put 26 volts thru it! OOPS!!! Rolling with laughter ... ,-------,
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #568519 3rd Oct 2016 11:35pm
Shax
Well, I finally got around to butchering the high level brake light to fit the LED panel...
Here's a pic of the back of the board almost bolted into place!
I was too keen to get it fitted to take any more pix!
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #606811 5th Mar 2017 1:20am
Good job shax, neat soldering Thumbs Up
Post #606818 5th Mar 2017 7:25am
Shax
All fitted and working!!
A few more pix of the LED brake light panel...
I re-made the brackets this morning to give a better clearance, and then went out and re-fitted the bits as shown in the pix...
.. I [__][_]|__
.. I __ |"_|"__|
.. "(o)====(o)"
PAUL
G7ALW 14.200 USB
Post #606941 5th Mar 2017 5:09pm
Page 2 of 2 <12
