Home > In Car Electronics > High Level LED brake light |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20348 |
Feeding the wire up the door frame and out you'll have fun with.
I'm assuming you are using the standard wiring rubber boot to gain entry to the door? |
13th Sep 2016 7:19pm |
Shax Member Since: 05 Oct 2010 Location: London Posts: 391 |
Yeah, standard as far as I can go without drilling more holes.. ... ,-------,
.. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
13th Sep 2016 9:31pm |
Defenders with 3rd brake light factory fitted have a hole up there with grommet in I'd imagine?
Needs a cable puller or a homemade type of puller to get it through. |
13th Sep 2016 10:53pm |
Nah... The feed is by the heated screen printed tracks... Wires exit the door at the bottom of the window... ... ,-------,
14th Sep 2016 8:42pm |
Alexke Member Since: 03 Jan 2011 Location: Antwerp Posts: 113 |
Just use
http://www.3rdbrakeflasher.com/brake-light...p-183.html it also has a G-sensor. Discovery 4 SDV6 Landmark F31 320dA Msport xDrive LR Defender 90SW TD4 Stornoway grey 320d E46 E70 X5 3.0d Sold! FFRR TD6 - Sold |
15th Sep 2016 8:09am |
Yeah, I could do that, but I where's the fun? I like messing with microcontrollers and accelerometers!
... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
15th Sep 2016 10:02pm |
I aint forgot about finishing this post.. Just waiting on some fresh LEDS to turn up..
The last panel had me f*ck up, and put 26 volts thru it! OOPS!!! ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
3rd Oct 2016 10:35pm |
Well, I finally got around to butchering the high level brake light to fit the LED panel...
Here's a pic of the back of the board almost bolted into place! I was too keen to get it fitted to take any more pix! Click image to enlarge ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
5th Mar 2017 12:20am |
Good job shax, neat soldering
5th Mar 2017 6:25am |
A few more pix of the LED brake light panel...
I re-made the brackets this morning to give a better clearance, and then went out and re-fitted the bits as shown in the pix... Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge ... ,-------, .. I [__][_]|__ .. I __ |"_|"__| .. "(o)====(o)" ^^_-^-_^-^_^^^^^--^^^^ PAUL G7ALW 14.200 USB 26FB458 / 27.275 SSB |
5th Mar 2017 4:09pm |
