Home > My Defender > An Anoraks Tdi Defender 90
Page 17 of 24 <123 ... 161718 ... 222324>
Nope, which is why I've attempted a repair. Darren
Post #646356 25th Aug 2017 9:12pm
Procta
I think I found a land rover dealer that "some in stock", after looking on here. They wanted close to £300 quid! not worth it at all for what it is! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
In the words of my Good Friend, Gary Forrest 1980 -2025
" we will work something out"
Post #646378 26th Aug 2017 1:00am
legin
United Kingdom 2012 Defender 90 Puma 2.2 HT Santorini Black
Even your bodge jobs are thought out and well crafted ,what's next Exclamation
Post #646386 26th Aug 2017 6:41am
Heh, heh, thanks Cool Still lots to do. It's become more of a rolling restoration than I originally planned, if I'm honest, and progress is limited by the amount of time I have to play. Darren
Post #646389 26th Aug 2017 7:34am
A few weeks ago I replaced the OSR hub seal but it's failed again Rolling Eyes
So this morning I did what I should have done first time around and checked the axle breather and, lo and behold, it was a cruddy mess that was blocked solid:
I then spent a happy hour cleaning, de-rustng and dismantling the damn thing until it was clear and free turning again:
Re-assembled and back on the axle, I hope that will solve the problem.
In other news, with the help of my darling wife I swapped the eight bolts securing the rear seat bases for slightly shorter ones so that I could finish them off with some nice caps. I also took the opportunity to install a couple of extra tie down D rings:
 Darren
Post #646575 27th Aug 2017 1:01pm
Profyaffle
Nice work there... :thumbs:
I don't have a turbo heat shield .. I've looked for one but they are way too pricey. 1993 200Tdi Defender 90
Post #646593 27th Aug 2017 3:17pm
Procta
looking very tidy! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #646663 27th Aug 2017 9:00pm
L110CDL
Professional job there LRA Thumbs Up Clayton.
Keeper.
Post #646832 28th Aug 2017 8:54pm
So, last week was quite successful. Firstly, I had the wayward steering repaired by Challenger 4x4, which involved replacing some bushes. It's now a lot more directional and I no longer have to telegraph left hand turns in advance! The next day it passed it's MOT with flying colours and at the same time I renewed my insurance for slightly less than last year Very Happy
Onto more mundane stuff this morning before rain stopped play:
Firstly, despite my success with the banjo bolt described above, I decided to replace them on both axles with these push-fit fittings, which was quite an easy job. I also replaced a few snapped cable ties that secure the breather pipes.
Next up was replacing an exhaust heat shield, which is a job that I've been putting off. Soon after I bought the vehicle I noticed that some of the brackets on the original had sheared, resulting in a bit of a rattle. After much scrabbling about and cursing underneath, I managed to persuade the four original bolts to part company and get it out.
The second clamp bracket appears to be welded to the exhaust, which I don't think is how it would have been originally Confused
Installing the new one was comparatively straightforward. I used new stainless bolts and took the opportunity to install it in the correct place on the exhaust as the original wasn't Rolling Eyes
The final task was to swap the plastic radiator bleed screw for a nice solid brass one. The originals have a habit of getting chewed up when removed whereas the brass version is much more robust:
With the securing brackets and top panel removed, it's possible to get a spanner on the plastic bleed screw:
When removed, the coolant should be right up to the top of the rad:
And the new brass screw in place:
This week I hope to return to painting as I really want to get the new rear door fitted. Darren
Post #648010 3rd Sep 2017 5:02pm
Profyaffle
It's looking good.. its very satisfying doing those little jobs... Can I ask does your bonnet have rubber buffers fitted to it at the front edge? Mine doesn't and it has been touching the wing slightly and rubbing the paint off in a couple of places. 1993 200Tdi Defender 90
Post #648261 4th Sep 2017 4:43pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Interesting result with the steering. The vagueness of the steering the biggest thing I notice from driving a "normal" car, I'll have to do some research as I suspect my bushes will also be shot. Thumbs Up Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #648264 4th Sep 2017 4:49pm
I'm not sure, to be honest Confused I'm not aware of it hitting anything so I expect so but I'll try and take a look this evening. Darren
Post #648438 5th Sep 2017 12:33pm
Defenders are notoriously vague compared to normal cars so that alone doesn't mean that something is wrong. Mine, however, had a lot more play when turning left than right so something was clearly amiss. Darren
Post #648439 5th Sep 2017 12:36pm
So, had a look last night and it does have the rubber buffers in place. Difficult to get a clear picture of but they're just the standard part.
On a different note, as my steering wheel has worn smooth I've been looking at replacement wheels, on and off, for a while. My problem though is that I quite like the standard wheel, which is the pre-fake airbag version. Anyway, inspired by a post by V8GPC on his 50th Anniversary thread, I bought a leather stitch-on wheel cover from eBay for £15.99 and then spent several hours over the last two evenings fitting it. I found it very fiddly to do and it became a bit of a labour of love but it feels great and I'm really pleased with the result:
I'll get if re-fitted tomorrow. Darren
Post #648700 6th Sep 2017 9:10pm
Profyaffle
Thanks.. I ordered a couple and fitted them.. my bonnet is now lifted on the rubbing side and sits level...
Nice work with the steering wheel.. I did the same with mine, makes them much nicer and less slippery Thumbs Up 1993 200Tdi Defender 90
Post #648712 6th Sep 2017 9:54pm
