Home > Maintenance & Modifications > Nakatanenga rear door gas strut V2
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Installed the gas strut last night, and having an issue with the fit.
Strut is the Post '02 model, rear door and door card are MY2014.
Installation was simple and straight forward, installed the new bracket and strut, works perfectly without the door card in place. However once the card is fastened, the strut cartridge pushes out on the card, popping out the bottom anchor. It happens as the door is about half way closed.
1st thought, flip the strut 180, so the cartridge is on the end closest the vehicle (oddly MUD UK's instructions show it this way, Nakatanenga's instructions show the opposite), same result. It seems the strut is pushing on the vertical edge of the recess of the card (see circled red area in the photo).
Strut is riveted in exact as per the instructions, as are the 2 pivot heads.
Anyone encountered this before??
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #557743 21st Aug 2016 6:22pm
TACK
Yes, on both the ones I brought. Couldn't get over it to be honest and have just put up with it.
Post #557745 21st Aug 2016 6:26pm
CDN38
Funny... how they don't mention THAT in the brochure....LOL
Thinking a work around may be to have the hole in the bracket slightly closer to the door, so it's not going to stick out so far at mid span. There's still some clearance room. Hmmm.... it's a Landrover thing...
Post #557746 21st Aug 2016 6:30pm
Screbble
Having posted earlier about the v3, I also find this post very interesting...... Thumbs Up
I am weighing up the pros and cons of both versions and am coming to the conclusion that there isn't a solution without its niggles.
Maybe I shall go back to the broom handle Whistle
I hope you get it sorted.
Post #557760 21st Aug 2016 6:54pm
MR_JAMES
United Kingdom 2011 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Yes! I fitted one a month ago and it does the same. 1953 80"
1987 mini city e
2011 90"
Post #557802 21st Aug 2016 7:46pm
foxyred
England 1994 Defender 90 200 Tdi HT Montalcino Red
I have the old version for the old door 200tdi, I now have a puma rear door made my own fixing flat plate and works great
Post #557810 21st Aug 2016 7:58pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
Have you got the correct number of spacers on the check fixing point. I fitted one to a 2011 90 in 2014 and had no trouble with the door card. Mine was possibly an earlier version though.
Post #557812 21st Aug 2016 7:59pm
thor44
2014 Defender 90 Puma 2.2 SW Indus Silver
I have the exact same issue on my MY14 90. I emailed the guys from Nakatanenga and Peter told me to heat the door card in the affected position with something like a hair dryer and gently bend it to fit the strut. It's all about 1-2 cm.
To be honest, I tried that and it didn't work too well. I was able to get it to a point where the bottom anchor isn't popping out anymore, but there's still a 5mm gap between the door and the door card. Maybe something with a little more heat would help. Wink . _____
.|_____\___
[|_/-\__/-\_|}
...(O)....(O)........ MY14 2.2 Defender 90 SW
Post #559902 30th Aug 2016 7:56am
CDN38
I think my plan is going to be to fabricate a new bracket for the strut to door end. When I look at the position of the cartridge, there is ample space between it and the door when it's at the closest point, room to fix the problem. I don't want to start grinding or warping a 6 month old $400 doorcard.
Frustrating to pay good money for something that obviously has fit issues from the get go. Disappointed to hear that the manufacturer can only say "modify your door card" Aren't they supposed to be making their products to fit our vehicles?
...other than the fit issue, it does the job quite well. it's a Landrover thing...
Post #560020 30th Aug 2016 5:33pm
miker
Without knowing the exact fitment issue (and having no qualms over cutting/modifying any parts of my interior) it isn't easy making a product fit into a space that was never intended for it, which could explain some of the fitment issues.
Post #560026 30th Aug 2016 5:45pm
Stiff1
I also have the V2 but have had no such problems, fitted to a 2007, one of the best mods to date.
I agree suppliers response should never be to alter the car to accommodate there part though.
Post #560096 30th Aug 2016 8:51pm
Perhaps the 2.2 and 2.4 door card is different?..
No probs with my 2.4 either.
Post #560105 30th Aug 2016 9:26pm
Screbble
Post #560108 30th Aug 2016 9:28pm
I have one of the earlier ones that fit lower down, wouldn't be with out it.
Had it for about 3 years and not a single issue. Mr. Green
Yes, if you have a jockey wheel when towing like I occasionally do it can be a bit annoying but a very small compromise to live with.
Every other thing is a psoitive.
Perhaps like suggested carry something to place on the jockey wheel, to protect the door.
Personally I don't find it much of an issue to worry.
Thumbs Up
Post #560113 30th Aug 2016 9:40pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
06 Td5 Fitted the MUD supplied v2 version and have had no problems fitting or use. Good mod, holds the the door firmly , big help when loading her ladyships wheelchair.
I moved the trailer jockey wheel to get clearance.
Post #560118 30th Aug 2016 9:47pm
