Home > Maintenance & Modifications > Intermittent brake squeal.
David-H.
Scotland 2014 Defender 90 Puma 2.2 HT Barolo Black
Hi all.
My 2014 90 is suffering from an intermittent brake squeal which I believe is coming from one of the rear wheels. It only manifests itself at low speeds, up to about 15 mph.
I took it into my local main dealer a couple of weeks ago as it is still under warranty but on two test drives over a couple of days they couldn't get it to appear, and couldn't spot any uneven wear on pads or disks They did kindly offer to strip and clean the brakes, all for the bargain price of £180, + VAT Shocked . Naturally I declined.
Does anyone have any suggestions / advice before I contact the dealer again?
Thanks - David.
Post #556894 18th Aug 2016 9:09am
Marks Landy
United Kingdom 1985 Defender 90 200 Tdi SW Java Black
Just take the wheels of give the pads and disks a good clean and put a bit of copper slip on the backs of the pads.
£180 saved...
Post #556947 18th Aug 2016 12:49pm
Gnasher141
United Kingdom 1986 Defender 90 V8 Petrol HT Sumatra Black
As Marks comment but also put a chamfer on the leading edge of the pads( about 3mm)
Post #557012 18th Aug 2016 4:27pm
