![]() | Home > In Car Electronics > Speaker upgrade, Amp or no amp - advice please |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5878 ![]() ![]() ![]() |
Calling all audiophiles.
As mentioned on other posts, I'll be looking to upgrade my speakers shortly. I am likely to get a Hertz set up (items listed below) and I am wondering whether or not I need an Amp, what is a Crossover (and do I need one) and should cables be upgraded at the same time? I shall be keeping it simple so will be choosing two 10cm speakers and two tweeters to replace the stock Puma items, and then will be adding a small sub to sit under the rear bench seat. I feel it should be enough in a DC, especially when 99% of the time just me and Mrs Grenadier will be tuning in. These are the items: https://www.amazon.co.uk/ECX-Hertz-100-5-W...z+speakers https://www.amazon.co.uk/Hertz-30-3-1000-W...z+tube+sub https://www.amazon.co.uk/Hertz-HT-25-Tweet...z+tweeters The speakers are listed as 40W RMS/120W max. The tweeters are listed as 120W max The Sub is listed as 300W RMS/1000W Max It is worth noting they will be fitted to a DC (which has a smaller can than a 90/110 SW) and which at the same time as fitting the speakers will be fully sound insulated with Silent Coat and Isolator 6 matting throughout. So there should be minimal ingress from Road/Wind/Rattle and other noises. My head unit is the following: http://www.crutchfield.com/S-NTPKJgREwKH/p...BT901.html In the bumpf it is listed as having the following: "built-in MOSFET amplifier (22 watts RMS/50 peak x 4 channels)" "outputs: 6-channel preamp outputs (4-volt front, rear, subwoofer)" "DSP features settings for car type, speaker size, digital time alignment, front and rear high-pass crossovers, and subwoofer low-pass crossover" As mentioned above, the cab should be well insulated and I am fairly honest about the practicality of high end systems in such a rattly vehicle, even once filled with Silent Coat. Further, my days of full volume rock are (mostly ![]() So my questions: Do I need an Amp (and if so, how powerful?) and/or Do I need a Crossover. (And if I do, what does it actually do?) and/or Should I upgrade the cabling as well? Advice from music geeks welcome.... ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Ta. It will be nice to go from 'audible' to 'amazing' And interesting, given what they've popped in, that the insulation is doing its job
![]() Was going Focal, but Hertz are as well reviewed in the know-what-they're-talking-about reviews, but say that for the mid value kit offer more for the money. So I can get a higher quality speaker for the same bucks or add a sub and/or amp etc. I might mount my stock speakers behind the rear seats, but there's no official trim so I'd have to rustle something up. But overall, if I do go the whole hog (2 X speakers, 2 X tweeters, 1 X sub, 1 X amp, 1 X crossover) should do the job in the cab. After all, I'll never be in the back being driven, so should suffice. All comes in any approx £300 which I think is good for what I'm getting. Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 ![]() ![]() |
Yep
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2654 ![]() ![]() |
If you want a VERY good setup, better than the 2015 Rs4 we have with a bang olufsen set up...
Focal, K2 KRS 100 in the front and PC100 rear driven off a HERTZ HDP4 amp, i then bridged the second channel to power a JL audio 12" sub, my plan was to eventually have the HDP4 run all 4 speakers and then a separate amp running the sub but the combo is just too perfect as it is. |
Whoa. Just looked up your kit, that's some monster power. I know you said it is amazing, would you say on the money or too much? Do you get close to the top end? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
LOMG, i suppose my statement is the same for you, in that that's mahoosive power. Bar a 90 pick up, I have the smallest cab volume so I don't want to over do it. Money is not so much the object (although The spare reddies can be spent on beer), just being sensible. Also, I think I would tackle the first phase as described above and if the sound is lacking (from a quadrophonic point of view) will then make a bracket and fit some extra co-ax's in the back, perhaps some 16cm....All in 500W (if I get the amp) which I would have thought would be enough? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
all this speak has got me excited and i've just bought a HDP1.... finally release the full potential.
i guess the more power you have on offer, you won't be running the gear at full power all the time, on my clarion head unit, i usually go to 20-23, 26 is max on a scale of 1-40 as above 26 is mental loud. |
Is it? LOL To be honest I had no idea what I was agreeing too when I had that done, I just trusted what they said, and they were right, it does sound amazing. As for the money? I've no idea. It was quite expensive, especially with that head unit, but to me it's been worth it. The woofer is really the nice, very bassy but very small, it takes up no room tucked away behind the cubby and it doesn't get in the way of the front seats when reclined. ![]() Click image to enlarge I took what they call their Premium audio package, but they also now offer a higher spec one with a 5 channel amp and extra speakers under the front seats. I'm sure that sounds great but mine is more than good enough for me and Barry Manilow as we poodle around Provence ![]() Last edited by Riverboy on 16th Aug 2016 3:03pm. Edited 4 times in total |
Ah, the head unit is the only bit I didn't look up, but I seem to remember you went Double Din?
No real idea if it was too powerful, just that your kit has some very big numbers listed, but I actually have no idea!! ![]() If you like it, and you do, that's all the matters ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
I discovered recently that my head unit plays DVD movies and MKV/MP4 format movies etc on a USB drive. Very handy on a long drive eh!
I prefer to play Scrabble on long drives, although it's a
![]() ![]() I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
What's the bar running under the sub and behind the seats? Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
Ryderoo Member Since: 28 Aug 2015 Location: South Oxfordshire Posts: 1666 ![]() ![]() ![]() |
Grenadier, I think that is the bulkhead removal bar, you can see it a bit better in my 90.
![]() I can explain it to you, but I can't understand it for you 1990 110 TD5 county, my first Land Rover - gone 2012 Discovery 4 XS SDV6 - gone 2014 Discovery 4 XS SDV6 - gone 2015 Evoque SD4 dynamic - Wife’s - gone 2015 Urban Truck 90 XS Santorini Black Hard Top - Reluctantly gone 2020 Discovery 5 Eiger Grey 3.0 SE - gone March 24 2021 Defender S D250 Santorini Black 110 HT - gone March 24 2023 Evoque P300e SE wife’s current vehicle |
^^^ Roger
