Home > Maintenance & Modifications > Racor: 2nd Diesel Filter
Page 2 of 2 <12
Yannis
United Kingdom 2015 Defender 90 Puma 2.2 CSW Corris Grey
Bushpig wrote:
As far as I'm aware, they are the same.
Perhaps the connectors could be different? (1st picture)
But then you could use the connectors off the original pipe.
I would still do regular checks on the original filter though...
Hi Bushpig,
If you have a chance, would you mind having a look at the size of the pipe that came in your kit? Hopefully the ID & OD are written on it.
Yan
Post #777017 11th Jun 2019 7:53am
Bushpig
Wales 2012 Defender 110 Puma 2.2 SW Alpine White
Hi Yan
I would love to, but currently I'm living in Wales and the Landy is still in South Africa Big Cry
I'll ask the family she is parked with if they can have a look for anymore markings (could take a week or 3 though).
Apologies for missing your previous question, about the original pipe.
That one is in a box in storage in Johannesburg.
Did a quick look through my photo library, and found these...
Original:
Kit:
Cheers Jason Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #777124 11th Jun 2019 8:10pm
Yannis
Hi Jason,
Thanks for that.
Looks like 1\2 and that seems to match up with what I measured today.
Found a company in the UK that can get everything together for about £100 including a spare filter and all fittings etc.
Yan
Post #777134 11th Jun 2019 8:29pm
Bushpig
Good Job...
With the current exchange rate, it's about the same price, without the postage from SA.
Hoping to get mine over here in the next 18 months.
Biggest worry is secure parking!
Completely shocked at how many are stolen/abused on this island... Human beings, who are almost unique in having the ability to learn from the experience of others, are also remarkable for their apparent disinclination to do so.
Douglas Adams
2012 2.2 Puma
Post #777138 11th Jun 2019 8:38pm
Yannis
Your bringing your Defender North, and we are taking ours South....
November we start a 6 month trip; Milan - Capetown, hence fitting another fuel filter.
P.s, May 2020 there might be space for an extra Defender in our container; SA - EU
Post #777161 11th Jun 2019 10:29pm
RobM
Australia 2010 Defender 110 Puma 2.4 SW Chawton White
Bushpig wrote:
Hi Yan
Kit:
Cheers Jason
Hi Jason....
Hoping for some advice/help...
We recently did a trip out into the Desert here in Australia and I ended up having problems with a bad batch of fuel. From what we could determine, something was blocking the fuel pickup when i got down to a certain level. We tried disconnecting the fuel hose at the OEM Filter in a hope that we could blow air back up through the fuel line to blow clear what ever was blocking the fuel pickup. I tried for a while to remove the fuel Quick-fit connection but could not and I ended up breaking the small blue clip that I since found out that u are suppose to push inwards instead of outwards. I'm assuming to fix/replace this connecter that I now have to replace the whole fuel line hose between the tank and filter ??
I'm now wanting to either replace the OEM filter with something better that has a buit-in primer or if I cannot do that, then install a 2nd Aux fuel filter which had a primer as well. The problem here in Aust is finding those Fuel line Fittings; the hose Barbs and also finding out the actual size of the OEM Nylon Fuel Hose.
Any help/advice would be greatly appreciated
Rob Cheers.....
Rob
1995 Defender Tdi 110Wgn
2010 Defender PUMA 110Wgn
TRIPS: Meanderingdownunder WikiLoc Trips
Post #790214 3rd Sep 2019 9:27am
Page 2 of 2 <12
