Home > My Defender > Patsy, our 110 Hardtop
Page 2 of 2 <12
Andrew*Debbie
July Part 2
Late July I drove the 110 down to a friend's workshop near Leamington Spa. We did a full DIY Dinitrol of the chasis and underbody. I've covered this in another thread so I won't go into details here. It was messy but I'm quite pleased with the way it turned out.
Post #554805 9th Aug 2016 8:29pm
Andrew*Debbie
July, Part 2a
The 110 came with a few loose parts in the back. There was a set of windscreen wiper blades, grill and light surrounds in silver and a pair of aftermarket fire and ice side steps.
I cleaned and polished the side steps the first weekend we had the truck but I wasn't able to figure out how to mount them.
My friend, an engineer at JLR and a Defender expert, fitted them for me. I would have gone for a little less bling, but I already had these so on they went.
We also discovered a set of wheel spacers behind the steel wheels. Rather than remove the spacers, we adjusted the locks to get a little tighter turning circle.
Post #554811 9th Aug 2016 8:41pm
Andrew*Debbie
This past weekend:
I fished out a broken captive nut I suspected was sitting at the bottom of the A-pillar.
I fixed a problem with the rear door check.
I sprayed Dinitrol into the A-pillars and the rear door:
I replaced rusty bolts on the rear door and spare wheel carrier with parts from my SS kit.
Before:
After:
and I did this:
I noticed the backup light stopped working, but I haven't had a chance to check anything yet.
Post #554818 9th Aug 2016 8:57pm
L110CDL
Well done with all the jobs you have done so far, a great sense of achievement once they get ticked off, once again, great work Thumbs Up Clayton.
Keeper.
Post #554826 9th Aug 2016 9:10pm
Rosco
United Kingdom 2015 Defender 110 Puma 2.2 XS CSW Montalcino Red
Looks like a busy and productive weekend Thumbs Up 2007 - Stornoway Grey 90 XS SW - Gone
2002 - Black Discovery II - Gone
2014 - Montalcino Red 110 XS SW
Post #554846 9th Aug 2016 9:54pm
Andrew*Debbie
This past weekend I spent a few hours troubleshooting a fault with the reversing light and rear park assist.
Our Defender has a alphamotiva rear park assist. The park assist is powered by the reverse light.
My first instinct was to check for a bad install and loose wire. No luck. It was done professionally. They made up a harness that plugged into the original light socket. I plugged the rear fog lamp into reverse socket - no light...
I did some other basic troubleshooting at the back of the car and i checked for power at the fuse. All good.
With today's warm weather, the park assist and reverse light started working. That sure sounds like a sticking reverse switch to me. I'll be checking that next.
Might not get a change to do any work this weekend or next. Doesn't look like the easiest job either.
Post #556534 16th Aug 2016 9:09pm
Page 2 of 2 <12
