Home > Puma (Tdci) > Help! Yet another 2.4 Puma not starting |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4216 |
Anyone? I was meant to be going out tonight
Fuses all look healthy. Don't really know what I'm looking at with the relays, there seems to be a lot of them and no means of identifying them. I disconnected the battery for a bit and reconnected, still same. |
3rd Aug 2016 5:07pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17432 |
Several things could cause this, my first suspicion would be crankshaft or camshaft position sensors.
3rd Aug 2016 6:12pm |
Can they be tested?
I could do with a logical diagnostic process. Is that possible without the fancy diagnosis tools? |
3rd Aug 2016 6:14pm |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
do you have any sort of diagnostics tool? It's possible with the cheap ones too.
Have you tried locking it, setting the alarm, and then trying again? I've had issues with the immobiliser before that have been fixed by turning the alarm on and off. |
3rd Aug 2016 8:34pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20430 |
Leaving the battery disconnected completely for a while then reconnected could be worth a try too.
Basic, but easy to eliminate. Last edited by custom90 on 4th Aug 2016 4:23pm. Edited 1 time in total |
3rd Aug 2016 8:38pm |
I have cheapo diagnostic tool which says no DTCs stored. Have armed and disarmed the alarm too. I did leave battery disconnected for about 10mins to no avail either. A chap on Angry Puma's Facebook group is holefully going to help me out with his Lynx diagnostic tool tomorrow, hopefully that will shed some light on the situation. I'm sort of thinking its alarm/immobiliser related but I don't really know why. |
3rd Aug 2016 8:58pm |
SimonDavies Member Since: 15 Mar 2012 Location: Swansea Posts: 244 |
I would also say it could be a crank sensor fault. Hopefully his diag tool will have live data and you can see if the ecu is seeing rpm.
3rd Aug 2016 10:32pm |
It turns out the camshaft position sensor has died.
Does anyone know the Ford equivelant part number for one, so I can try the local Ford dealer tomorrow. |
4th Aug 2016 4:11pm |
4th Aug 2016 4:26pm |
this may help
camshaft position sensors. ford part number 1358343 Last edited by dorsetsmith on 5th Aug 2016 7:41am. Edited 1 time in total |
4th Aug 2016 4:41pm |
Is this one of those sensors it's worth keeping one of in my box of bits as it can disable the vehicle in the middle of nowhere?
5th Aug 2016 7:30am |
I'll let you know the cost shortly and you can decide, but I'd say yes if you are going somewhere remote. Car completely disabled with no warning.
5th Aug 2016 8:02am |
£34.56 +VAT from Ford.
5th Aug 2016 8:13am |
No go with no warning and the part is cheap (half that from people other than Ford), I think I'll be picking one of them up then Thanks.
5th Aug 2016 10:10am |
