![]() | Home > Technical > Td5 air con issues |
below dash version
http://www.allbrit.de/UNI.cfm?PAGE=761591&SPRACHE=EN#1 show even less Last edited by dorsetsmith on 2nd Aug 2016 9:41am. Edited 3 times in total |
RCMike Member Since: 30 Apr 2015 Location: North Wiltshire Posts: 70 ![]() ![]() |
No idea what could be wrong unfortunately, but it should run continuously cold for many hours (i've had mine running cold for a 6 hour stint at least).
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2320 ![]() ![]() ![]() |
TD5 air con doesn't like running full tilt on the 3rd coldness for very long and you get a build up of ice on the evaporator. Try knocking the temp down to 1 or 2 after half an hour and give it a chance.
HTH Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
Millsy94 Member Since: 06 Jun 2013 Location: Gloucestershire Posts: 91 ![]() ![]() ![]() |
It ices up even on setting two (takes slightly longer) and setting one is just useless
Good old Land Rover 😊
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Does your compressor on the engine cycle on and off? It should. It does sound like your system is "freezing up" - the evaporator is getting frozen and not transferring cold to the air. You also may notice the volume of air has reduced as well.
I would check the thermostat on the evaporator. 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
This link is to the "in dash" aircon rather than the below dash version. I have not seen a TD5 with the in dash unit. The in dash unit has the vent flaps blocked off and plastic covers fitted where the vents were. 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
