Home > In Car Electronics > standard landrover radio - message 1 hour
Stacey007
Hello
I have the std Landrover radio and when I switch the car its not coming on, I switch the 'on' button on and the screen says '1 hour'
as if it's the setting without the keys in to let you listen?
Have a pushed a button and switched something? seems odd.
Works fine other than that and cannot see in the instructions what I have done?
Post #551069 25th Jul 2016 9:14am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Have you disconnected your battery (or has it drained flat)?
You could try switching ignition to acc 1, waiting the amount of time it is asking (or maybe more). Hopefully it will then change to allow you to input your radio code... so do that... TD5 Defender 90
Discovery 3 HSE
Post #551072 25th Jul 2016 9:33am
dorsetsmith
if not as ^^^^ check fuse as my one displays 1 hour auto switch off if in ignition key is off so that it not dis chard the battery
Post #551074 25th Jul 2016 9:44am
Stacey007
Thank both,
its working fine no code needed etc and no the battery is ok.
It just doesn't come on on its own and when I press it on it says 1 hr.. odd
I've not actually been in it over an hour since its done this (this weekend) so not sure if it goes off?
Thanks
Post #551096 25th Jul 2016 11:07am
Green Machine
Sounds like the HU is not getting its ignition live feed for some reason? 2005 Td5 | 90 Station Wagon | Tonga Green
Post #551112 25th Jul 2016 12:28pm
Dave-H
Standard radio does have a '1 hour' on setting which means with ignition off radio will play for one hour before automatically switching off .
As to why yours will only work on this, it can only really be a ignition controlled live fault, time to get out the multimeter .. Guns and Landrovers .... anything else is irrelevant.
Post #551203 25th Jul 2016 8:20pm
Stacey007
^ Thanks all
Due on holiday Wednesday so will have to wait, as long as after 1hr I can turn it back on Smile
Will look on return
Thanks
Post #551204 25th Jul 2016 8:26pm
HardCharger
When this happens, do you have use of the AC blower and have power in the lighter socket? If not, it's most likely related to the ignition switch. Once you replace that, all should be well again.
Post #551254 26th Jul 2016 4:53am
Stacey007
Everything else in the car seems to be working
Literally just went out to check the A/C as going on holiday tomorrow and need that Smile
Post #551286 26th Jul 2016 8:47am
