Home > In Car Electronics > standard landrover radio - message 1 hour |
huffhuff Member Since: 05 May 2016 Location: Home Counties Posts: 379 |
Have you disconnected your battery (or has it drained flat)?
You could try switching ignition to acc 1, waiting the amount of time it is asking (or maybe more). Hopefully it will then change to allow you to input your radio code... so do that... TD5 Defender 90 Discovery 3 HSE |
25th Jul 2016 9:33am |
Click image to enlarge if not as ^^^^ check fuse as my one displays 1 hour auto switch off if in ignition key is off so that it not dis chard the battery Last edited by dorsetsmith on 25th Jul 2016 12:41pm. Edited 1 time in total |
25th Jul 2016 9:44am |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3773 |
Thank both,
its working fine no code needed etc and no the battery is ok. It just doesn't come on on its own and when I press it on it says 1 hr.. odd I've not actually been in it over an hour since its done this (this weekend) so not sure if it goes off? Thanks |
25th Jul 2016 11:07am |
Green Machine Member Since: 19 Nov 2010 Location: North Yorkshire Posts: 1226 |
Sounds like the HU is not getting its ignition live feed for some reason? 2005 Td5 | 90 Station Wagon | Tonga Green
25th Jul 2016 12:28pm |
Dave-H Member Since: 08 Feb 2011 Location: Surrey Posts: 1507 |
Standard radio does have a '1 hour' on setting which means with ignition off radio will play for one hour before automatically switching off .
As to why yours will only work on this, it can only really be a ignition controlled live fault, time to get out the multimeter .. Guns and Landrovers .... anything else is irrelevant. |
25th Jul 2016 8:20pm |
^ Thanks all
Due on holiday Wednesday so will have to wait, as long as after 1hr I can turn it back on Will look on return Thanks |
25th Jul 2016 8:26pm |
HardCharger Member Since: 03 Mar 2013 Location: Manila Posts: 740 |
When this happens, do you have use of the AC blower and have power in the lighter socket? If not, it's most likely related to the ignition switch. Once you replace that, all should be well again.
26th Jul 2016 4:53am |
Everything else in the car seems to be working
Literally just went out to check the A/C as going on holiday tomorrow and need that |
26th Jul 2016 8:47am |
