![]() | Home > Maintenance & Modifications > bulkhead vent not shutting fully |
Check your seals, they can come apart and sag causing them to prevent it from shutting properly. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter ![]() |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
Lube the hinges???Or/and fit stainless hinge pins. Pov.spec,ftw. 2006, 110,TD5.
Also check the tiny bolt that holds the flap to the reach rod is done up. If its too loose it wont pull up tight, if its too tight it wont move properly.
You will need tiny child like hands to do it though as it is fiddly as a fiddly thing. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
Fatboy Slim Member Since: 04 Feb 2008 Location: Bridgend Posts: 1006 ![]() ![]() |
I've had several Tdis do this to me in the past. If all else fails open the flap, grab the linkage from outside with a pointy pliers and twist to put a bit of a Z bend in it.
Oil and work the hinge until it frees up and it should shut nicely Ray
