Home > Maintenance & Modifications > bulkhead vent not shutting fully
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
Its been like this since i got it last year and last winter i took to fitting plastic bags to keep the draft out on the motorway!
With one eye on the next few months i need to sort this, the passanger one shuts fully but the drivers one has a slight gap when shut. Can they be adjusted because i can push it tighter to the bulkhead from outside 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #549397 17th Jul 2016 9:39pm
shaggydog
Check your seals, they can come apart and sag causing them to prevent it from shutting properly. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Self confessed mileage hunter Very Happy
Post #549522 18th Jul 2016 12:58pm
jimbob7
Lube the hinges???Or/and fit stainless hinge pins. Pov.spec,ftw. 2006, 110,TD5.
Post #549523 18th Jul 2016 12:58pm
shaggydog
Also check the tiny bolt that holds the flap to the reach rod is done up. If its too loose it wont pull up tight, if its too tight it wont move properly.
You will need tiny child like hands to do it though as it is fiddly as a fiddly thing. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #549524 18th Jul 2016 1:01pm
Fatboy Slim
Wales
I've had several Tdis do this to me in the past. If all else fails open the flap, grab the linkage from outside with a pointy pliers and twist to put a bit of a Z bend in it.
Post #549528 18th Jul 2016 1:17pm
mk1collector
Oil and work the hinge until it frees up and it should shut nicely Ray
My build thread
Post #549548 18th Jul 2016 2:24pm
