Home > My Defender > Charcoal's Defender 110 station wagon V8
Page 5 of 6 <123456>
charcoal
United Kingdom 2005 Defender 110 Td5 HT Bonatti Grey
That it does! Even if you have the loud transmission whine from the LT85 over the top of it.. I guess the fuel would only really be an issue if you had to commute 30 miles a day like some people. 1999 Land Rover Defender 110 td5 station wagon
1998 Land Rover Defender 110 County Station Wagon ~ Sold
1995 Land Rover Defender 110 V8 Station Wagon ~ Sold Sad
1985 Land Rover 110 ex mod project Tithonus ~ Sold Sad
Post #576712 9th Nov 2016 11:54pm
L110CDL
Thats why i have got a diesel, would love the V8 under the bonnet but the fuel bills would be Big Cry Perhaps one day ( Im dreaming again ) Rolling with laughter Clayton.
Keeper.
Post #576957 10th Nov 2016 8:51pm
charcoal
You could always get a GM diesel v8 fitted, they give similar mpg figures as the 300tdi. 1999 Land Rover Defender 110 td5 station wagon
Post #577017 10th Nov 2016 11:31pm
charcoal
I needed to move the CB antenna as it was in the way of a future modification which will be fitted in the next couple of months. I also bought a more serious looking Sirio antenna to replace my tired and rusty stinger antenna.
Post #577022 11th Nov 2016 12:18am
charcoal
The next thing I needed to look at on the hunt for the misfire cure was the carburettors. I bought some which were supposedly rebuilt and fitted them.
These carburettors ran like Censored and no matter how I tuned them they were somehow worse than the original carburettors. I rebuilt the original ones myself and replaced most parts around the float bowl area. The floats themselves were fine but they were set about half a centimetre too low which I was hoping would be related to the misfire.
Believe it or not they are rebuilt. Didn't bother making them look new as they aren't for show.. and didn't have time.
Over the past weekend I fitted the rebuilt carburettors back onto the engine. When I got the first pair off I noticed these little toothed things that'd be in the throat of the carburettors. At first I thought they were the dreaded restrictors but did some research before whipping them off and found out they're actually supposed to help mix the mixture.
After a fairly easy job (apart from the two bottom-rear nuts) and a few hours the self rebuilt carburettors are finally fitted.
And shortly after that I was able to start it up for the first time.. I know the quality is terrible, It was dark and I was struggling to keep hold of my posh Iphone with oil covered hands Laughing
Another hour after that and I had the carburettors idling at a sensible speed and tuned back to a liveable condition. Sadly the motorway speed misfire is still around but it has cured the cold running misfire, for sure this time Cool
I have a plan in the works to hopefully sort this misfire out once and for all so I will update this thread when the plan comes into fruition Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #599996 8th Feb 2017 12:21am
Romadog
Can't beat the sound of an SU on suck !!
So have you now a 1/2" spanner cut in half then for the lower nuts?? Thumbs Up Thumbs Up Thumbs Up
Post #600108 8th Feb 2017 3:00pm
charcoal
They do sound good without the elbows on! I got an obstruction spanner set specially for the job. It's lucky I didn't cut one as I had to undo the lower nuts from the front underneath the carburettor, wouldn't have reached with a cut one Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #600110 8th Feb 2017 3:21pm
L110CDL
That engine sounds like i need one now Wink but only dreaming again Thumbs Up
Great to hear your engine Charcoal Bow down Clayton.
Keeper.
Post #600203 8th Feb 2017 8:54pm
charcoal
Make that dream a reality Clayton! The sound cannot be beaten Thumbs Up 1999 Land Rover Defender 110 td5 station wagon
Post #600264 8th Feb 2017 11:56pm
L110CDL
I know Charcoal but for everyday use Shocked , i will be so bankrupt, i will have to sell the landy to afford more fuel to put in it Rolling with laughter Clayton.
Keeper.
Post #600484 9th Feb 2017 8:53pm
charcoal
The fuel bills aren't to be underestimated. With the supposed rebuilt carburettors I was getting about 8 mpg so they had to come off. 1999 Land Rover Defender 110 td5 station wagon
Post #600549 9th Feb 2017 11:17pm
I remember when I had a Stage 1 V8 with those exact same carbs, it was always single figures on a cold morning. Fun though.
Isn't a misfire under load more likely to be electrical rather than fuel related? Coil, perhaps, or maybe HT leads? Darren
Post #600591 10th Feb 2017 8:19am
charcoal
That's what I thought at first as well. Replaced the dizzy, coil, leads and plugs which solved nothing. Now that the fuel clearly isn't the cause either I'm thinking it's a problem with the engine itself Confused 1999 Land Rover Defender 110 td5 station wagon
Post #600676 10th Feb 2017 2:46pm
Hmm, that is strange Confused I can't imagine what else it would be, to be honest. I can't think what sort of engine fault would produce a misfire under load.
Did you run your latest test with the air filter disconnected? It's clutching at straws a bit but a restriction in the intake may cause problems under load. Darren
Post #600681 10th Feb 2017 3:30pm
charcoal
No, Scared to take it all the way to the motorway then down the motorway with no air filter connected. I have some K&N filters, would they behave the same as no filter at all? 1999 Land Rover Defender 110 td5 station wagon
Post #600683 10th Feb 2017 4:05pm
