Home > Puma (Tdci) > Front sidelights only not working
Fish13
Scotland 2012 Defender 90 Puma 2.2 HT Tamar Blue
Just noticed that my front sidelights (both sides) have stopped working. Rears are fine and work.
Have tried a search, but can anyone help? First thought is a fuse, but which one? If both side lights have stopped at once, are they not independent fuses? Has anyone else had this problem?
Cheers,
Fish.
Post #548190 12th Jul 2016 5:11pm
andydef90
United Kingdom 2014 Defender 90 Puma 2.2 HT Corris Grey
hi fish its fuses f11 and f12 in your secondary fuse box worth a check at them plus the bulbs if there ok looks like a switch issue
Post #548445 13th Jul 2016 12:03pm
Cupboard
they are sort of independent, left (front and back) are paired, right (front and back) are paired.
Have a look at the wiring diagram:
http://sdrv.ms/1523pV3
At the bottom click on workshop and then your model year range.
Edit: just refreshed my memory. The positive is shared front to back - so the fact that the tail lights are working rules out the switch and the fuses. The negative is also shared, but with the corresponding headlight. There is very little (apart from the fact they're in the same loom) that's shared by the front sidelights and them only. Are the bulbs definitely good?
Post #548448 13th Jul 2016 12:05pm
Fish13
Excellent, many thanks for the info gents!
Cheers,
Fish
Post #548450 13th Jul 2016 12:11pm
K9F
http://www.defender2.net/forum/topic47846.html
Question If you go through life with your head in the sand....all people will see is an ar5e!!
Post #548467 13th Jul 2016 1:23pm
Fish13
Apologies, figured it was better off in the maintenance section but couldn't work out how to delete the TDCI one?
Post #548471 13th Jul 2016 1:42pm
Fish13
Turned out to be both bulbs blown. Thanks for the help and advice guys, appreciated.
Cheers,
Fish.
Post #549031 15th Jul 2016 6:23pm
