Home > Puma (Tdci) > Front sidelights only not working |
andydef90 Member Since: 09 Feb 2015 Location: yorkshire Posts: 617 |
hi fish its fuses f11 and f12 in your secondary fuse box worth a check at them plus the bulbs if there ok looks like a switch issue
13th Jul 2016 1:03pm |
they are sort of independent, left (front and back) are paired, right (front and back) are paired.
Have a look at the wiring diagram: http://sdrv.ms/1523pV3 At the bottom click on workshop and then your model year range. Edit: just refreshed my memory. The positive is shared front to back - so the fact that the tail lights are working rules out the switch and the fuses. The negative is also shared, but with the corresponding headlight. There is very little (apart from the fact they're in the same loom) that's shared by the front sidelights and them only. Are the bulbs definitely good? Last edited by Cupboard on 13th Jul 2016 1:19pm. Edited 1 time in total |
13th Jul 2016 1:05pm |
Fish13 Member Since: 17 May 2015 Location: Aberdeenshire Posts: 71 |
Excellent, many thanks for the info gents!
Cheers, Fish |
13th Jul 2016 1:11pm |
http://www.defender2.net/forum/topic47846.html
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Jul 2016 2:23pm |
Apologies, figured it was better off in the maintenance section but couldn't work out how to delete the TDCI one?
13th Jul 2016 2:42pm |
Turned out to be both bulbs blown. Thanks for the help and advice guys, appreciated.
Cheers, Fish. |
15th Jul 2016 7:23pm |
