Home > Technical > no reverse light , wheres the switch on a auto box , HELP |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Im guessing you have checked the fuse first and then the bulb?
Pete. |
19th Dec 2010 11:51am |
car-breaker Member Since: 19 Dec 2010 Location: WEST YORKSHIRE Posts: 5 |
Hi Pete , the bulb is fine & the fuses are nothing like the diagram on the back of the fuse cover ,all seem higher that what they should be & how do you get em out of that black holder once you pull em from the fuse box ? . the bulb does seem to sit quite loose in the the holder so it may be that , you wouldnt believe the mud that was behind the light unit when i undid the 2 screws & removed it . From what i can gather its a bit of a pain to start stripping out the cab to get to the switch so im really hoping its just a bad earth or somthing at the back , im rubbish at sparks so i phoned a local auto electrician whos quite good but he dont know when he could call to take a look as he's got a lot on this week & i really need this thing on the road for work , also the wipers stopped working so im waiting on a new wiper stalk(im guessing its that thats gone ) from ebay to arrive ,
cheers Paul |
19th Dec 2010 12:34pm |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
It'll be a ZF 4 speed box, should be more info about the reverse light location on the web if you'd got that info 1988 90 Td5 NAS soft top
2015 D90 XS SW |
19th Dec 2010 1:23pm |
cheers for that , ill have a look on google
19th Dec 2010 2:33pm |
