Home > Technical > no reverse light , wheres the switch on a auto box , HELP
car-breaker
Hi , as a owner & forum member i posted this on the disco3 forum last night but thought i'd get more replys on here so here we go again ,
we have just bought a 95 (m reg) defender 90 which has benn converted to an auto box (range rover box i believe) anyway ..no reverse light so i need to know where the switch is located on these boxes so i can see if thats the culprit , its been used off road and is caked in mud so i think the switch is the first thing to check unless you guys have any better ideas as to why its not working ?
cheers
Paul
Very Happy [/u]
Post #48994 19th Dec 2010 11:31am
Zinke
United Kingdom 2003 Defender 90 Td5 HT Epsom Green
Im guessing you have checked the fuse first and then the bulb?
Pete.
Post #48996 19th Dec 2010 11:51am
car-breaker
Hi Pete , the bulb is fine & the fuses are nothing like the diagram on the back of the fuse cover ,all seem higher that what they should be & how do you get em out of that black holder once you pull em from the fuse box ? . the bulb does seem to sit quite loose in the the holder so it may be that , you wouldnt believe the mud that was behind the light unit when i undid the 2 screws & removed it . From what i can gather its a bit of a pain to start stripping out the cab to get to the switch so im really hoping its just a bad earth or somthing at the back , im rubbish at sparks so i phoned a local auto electrician whos quite good but he dont know when he could call to take a look as he's got a lot on this week & i really need this thing on the road for work , also the wipers stopped working so im waiting on a new wiper stalk(im guessing its that thats gone Rolling Eyes ) from ebay to arrive ,
cheers
Paul
Post #49003 19th Dec 2010 12:34pm
Martin
Site Admin
It'll be a ZF 4 speed box, should be more info about the reverse light location on the web if you'd got that info Smile  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #49008 19th Dec 2010 1:23pm
car-breaker
cheers for that , ill have a look on google Thumbs Up
Post #49015 19th Dec 2010 2:33pm
