![]() | Home > Td5 > TD5 Clutch.... |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 ![]() ![]() ![]() |
Try some lube on the pedal pivot.
If that doesnt help then im sure there is a spring you can add to help out like the 300 tdi had. Pete |
mikeyp Member Since: 14 Sep 2010 Location: Londinium Posts: 104 ![]() |
Bump
Any more info anyone? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6647 ![]() ![]() ![]() |
I believe the Td5 already has an assistance spring.
Get her to drive a 200 Tdi or earlier for a week, she'll be glad of the Td5 clutch then! ![]() Check the spring isn't missing would be a first start. ![]() ![]() |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6150 ![]() ![]() ![]() |
On my old 110, the spring snapped in half... a quick peek at the underside of the pedal should see it, and you'll easily tell if it's broken, or popped out of the "hole" that it should be pokng through.
