Home > Td5 > TD5 Clutch.... |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Try some lube on the pedal pivot.
If that doesnt help then im sure there is a spring you can add to help out like the 300 tdi had. Pete |
18th Dec 2010 8:32pm |
mikeyp Member Since: 14 Sep 2010 Location: Londinium Posts: 104 |
Bump
Any more info anyone? |
21st Dec 2010 8:55am |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6604 |
I believe the Td5 already has an assistance spring.
Get her to drive a 200 Tdi or earlier for a week, she'll be glad of the Td5 clutch then! Check the spring isn't missing would be a first start. 1988 90 Td5 NAS soft top 2015 D90 XS SW |
21st Dec 2010 9:26am |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6091 |
On my old 110, the spring snapped in half... a quick peek at the underside of the pedal should see it, and you'll easily tell if it's broken, or popped out of the "hole" that it should be pokng through.
21st Dec 2010 7:01pm |
