Home > Maintenance & Modifications > bmw 3.0 into a defender. .... |
Grenadier Member Since: 23 Jul 2014 Location: The foot of Mont Blanc... Posts: 5844 |
I'm certainly no specialist, but it's something I'd love to do as well. Initial thoughts are would it not be better to get a little bit of info from Nene/Bowler/Twisted who have all made similar upgrades? If only to recommend what would be the best engine? Most seem to stick with Chevvy or JLR powerplants. Surely a Beemer would be even more techy with a lot of unnecessary cross-pollination of brands and parts etc? Good luck anyway, will be interested to see your progress. Monsieur Le Grenadier
I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
21st Jun 2016 12:20pm |
s410man Member Since: 20 Jun 2016 Location: brecon Posts: 3 |
From what I've learnt it appears to be quite a simple engine with a off the shelf loom available to make it run properly
M57 engine is what i would like but there's a few different types of them!! Twin turbo any more difficult to do or.... |
21st Jun 2016 12:24pm |
big steve Member Since: 24 Dec 2009 Location: hertfordshire Posts: 2456 |
3.2 tdci 2.2/2.4 big brother pretty much straight fit 240hp 700nm
Simples 2015 2.2 tdci hardtop xs 3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P hybrid turbo in build -done ready to fit ashcroft atb in transfer box 6 speed auto in build |
21st Jun 2016 7:38pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3763 |
^ is that a 3.2 out of say the new ford Ranger?
What other model has it fitted? |
21st Jun 2016 7:54pm |
Wandathe110 Member Since: 10 Apr 2016 Location: Manchester Posts: 65 |
There's a company that does a conversion kit for the Mercedes 3ltr I'm pretty sure there a v6 and a conversion for a 5 cylinder 2.8 both have been mated to auto boxes all i need to do is remember where I've seen it
http://www.gaz-fab.co.uk/node/23 Got to go game of thrones to watch |
21st Jun 2016 8:19pm |
Transit is the engine needed 2015 2.2 tdci hardtop xs
21st Jun 2016 8:25pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10810 |
W110 the article you saw was in one of the LR mags, it was for the straight 5 cylinder in the disco 2 and the straight 6 in the Defender sounds good. 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
21st Jun 2016 8:39pm |
LRO where i seen it looked really interesting
See link. http://www.gaz-fab.co.uk/node/23 |
21st Jun 2016 9:25pm |
Andrew*Debbie Member Since: 25 May 2016 Location: Anglesey Posts: 95 |
How about an old BMW M30? They are rock sold with no plastic parts to break. The M30 is good for 200,000 to 300,000 in a BMW 5 or 7 series. Stock they peak out around 200HP but can be modded for more.
The newer motors are more powerful and lighter but have a lot of plastic that only lasts about 7 years before failing at the most annoying intervals. Water pipes and the thermostat housing are the biggest problem but I'd be careful about a recycling a used intake manifold too. You also have to contend with variable valve timing (VANOS) on the newer motors. It is great when it works and is fairly solid. VANOS from a scrap yard motor could be trouble. The M30 5 and 7 series used a ZF 4 speed. I know I've seen a Defender with a ZF 4 speed in it. If you want a newer motor (M30 is about 25 years old) how about the N52 or N53, the last of the naturally aspirated inline-6 BMW motors. These motors are light and have a magnesium block Both are good for ~270HP if you find the right variant. Look for a 330i or something with 3.0si in the name. Last edited by Andrew*Debbie on 22nd Jun 2016 1:32pm. Edited 1 time in total |
22nd Jun 2016 1:07pm |
The Hulk Member Since: 13 Apr 2016 Location: Aberdeenshire Posts: 81 |
The M57D30 was used in the Range Rover so you'd be doing an RR-LR transplant. The M30 is a wonderful engine but it's a petrol. I have two cars with this engine; one has twin turbos and puts out 520Nm of torque Mid Life; Live It! Ongoing thread: http://www.defender2.net/forum/topic45697.html 110 300Tdi Utility (Hulk) 90 300Tdi SW (GF's Tank) |
22nd Jun 2016 1:20pm |
Of course. Using a RR motor could make things easier, especially if the transmission can be make to work in a Defender.
There are also the rare South African Defenders that came from the factory with a BMW petrol M52. |
22nd Jun 2016 1:30pm |
muddypaws Member Since: 22 Jan 2013 Location: Leicestershire Posts: 122 |
To put a spanner in the works, back in my cobra kit car days, a popular, under used transplant was the Lexus LS400.
Lightweight, bomb proof & easy to set up auto or manual - come by very cheaply, the only disadvantage being a big rusty car attached! just a thought..... Richard Defender 90 SVX |
22nd Jun 2016 2:24pm |
......assuming you don't mind going to petrol of course Richard
Defender 90 SVX |
22nd Jun 2016 2:56pm |
In effect what Bowler did with ther DC. A JLR 4ltr unit from the F Type, which I assume would be the same used in the RR Supercharged, and using the F Type 7-speed auto transmission. 440bhp. Even the twin under slung exhausts are from the F Type. If I had the money...... Click image to enlarge Monsieur Le Grenadier I've not been everywhere, but it's on my list..... 2011 Puma 110DC - Corris Grey |
23rd Jun 2016 8:29am |
