Home > Tdi > Tuning to remove smoke
The Hulk
Scotland 1997 Defender 110 300 Tdi HT Aintree Green
The Hulk currently smokes like a chimney on anything other than a light throttle and I'm very keen to clean it up. He's had the EGR removed and a straight through exhaust fitted by the PO but I don't know what's been done to the fuel pump.
I've got several 'how to' guides which are great but all start with the premise of marking the original position so that settings can be returned. The trouble is I don't want to return these settings because they're clearly not right. I suspect someone has had a go at it and got it wrong. Is there any guidance for a starting position which isn't factory standard? Mid Life; Live It!
Ongoing thread: http://www.defender2.net/forum/topic45697.html
110 300Tdi Utility (Hulk)
90 300Tdi SW (GF's Tank)
Post #540057 14th Jun 2016 1:29pm
Retroanaconda
Unfortunately there is no way to reset to factory settings without all the build information for the pump and vehicle. A diesel specialist can do this but obviously will charge you. You can get the 'settings' off a known standard pump (i.e. so many threads showing on this screw etc. etc.) but it's not a true reset as each pump will have slightly different settings.
In your position you can have a go at changing the settings, however you'll still want to mark to be able to return to the current setting regardless of whether it is 'right' or not. I'd start with the fuelling screw on the rear of the pump, this sets the overall fuelling level and so black smoke on any throttle position suggests this is set too high. Adjust that so as to lessen the fuelling slightly and see what happens.
I'm not sure if it's in or out to lessen the fuelling on that screw - I've never adjusted the settings on my vehicles, can't see the point personally.
Post #540076 14th Jun 2016 2:20pm
jst
if you look at the diaphragm it will prob have the fuel metering pin marks on the side of it from the original position. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #540171 14th Jun 2016 7:30pm
