![]() | Home > Tdi > Tuning to remove smoke |
The Hulk Member Since: 13 Apr 2016 Location: Aberdeenshire Posts: 81 ![]() ![]() ![]() |
The Hulk currently smokes like a chimney on anything other than a light throttle and I'm very keen to clean it up. He's had the EGR removed and a straight through exhaust fitted by the PO but I don't know what's been done to the fuel pump.
I've got several 'how to' guides which are great but all start with the premise of marking the original position so that settings can be returned. The trouble is I don't want to return these settings because they're clearly not right. I suspect someone has had a go at it and got it wrong. Is there any guidance for a starting position which isn't factory standard? Mid Life; Live It! Ongoing thread: http://www.defender2.net/forum/topic45697.html 110 300Tdi Utility (Hulk) 90 300Tdi SW (GF's Tank) |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8171 ![]() ![]() ![]() |
if you look at the diaphragm it will prob have the fuel metering pin marks on the side of it from the original position. Cheers
