Home > Puma (Tdci) > Diagnostics plug |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
Right hand side of the fuses towards the top, it is about 50mm long and 10mm wide and rounded at the ends (like you'd expect the scangauge plug to go on to). You have to undo the two fuse panel lugs to get to them and the plug. On a right hand drive it is under the steering wheel. I assume the same applies to a left hand drive. 110 2.4TDCi
110 300Tdi LROCV ::: AULRO.com |
10th Dec 2010 1:18pm |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
In the left hand drive it is here:
Click image to enlarge At the place where red square is - the socket is moved outside and placed by tie-wrap to allow ScanGauge connection.[/img] Janusz www.yahodeville.com |
10th Dec 2010 1:42pm |
tmcwhirter Member Since: 02 Dec 2010 Location: UK Posts: 23 |
Got it, thanks.
Anyone ever used this an an alternative to Scanguage etc: http://www.amazon.com/GL1-OBD-II-iPhone-Go...B00336S7KS Looks like the iPhone app actually reads the fault code and gives you a description. Cheaper too! |
10th Dec 2010 2:00pm |
iruffell Member Since: 03 Sep 2010 Location: Marlow, Buckinghamshire Posts: 343 |
Looks good, works out at £81 delivered to UK, I also notice they have a bluetooth version coming, might be worth waiting for that? http://www.gopointtech.com/
10th Dec 2010 2:16pm |
