Home > Puma (Tdci) > Diagnostics plug
tmcwhirter
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Stornoway Grey
Diagnostics plug
Where is it? Can someone take a photo and post it? I had presumed under the steering wheel but after taking the cap off and having a look it appreas that all the plugs have cables in them... trying to work out where to plug in a diagnotics tool (Scanguage or the like).
Post #48080 10th Dec 2010 8:17am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Right hand side of the fuses towards the top, it is about 50mm long and 10mm wide and rounded at the ends (like you'd expect the scangauge plug to go on to). You have to undo the two fuse panel lugs to get to them and the plug. On a right hand drive it is under the steering wheel. I assume the same applies to a left hand drive. 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #48104 10th Dec 2010 12:18pm
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
In the left hand drive it is here:
At the place where red square is - the socket is moved outside and placed by tie-wrap to allow ScanGauge connection.[/img] Janusz
www.yahodeville.com
Post #48110 10th Dec 2010 12:42pm
tmcwhirter
Got it, thanks.
Anyone ever used this an an alternative to Scanguage etc:
http://www.amazon.com/GL1-OBD-II-iPhone-Go...B00336S7KS
Looks like the iPhone app actually reads the fault code and gives you a description. Cheaper too!
Post #48112 10th Dec 2010 1:00pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Looks good, works out at £81 delivered to UK, I also notice they have a bluetooth version coming, might be worth waiting for that? http://www.gopointtech.com/
Post #48114 10th Dec 2010 1:16pm
