Home > Maintenance & Modifications > Retro-fitting headlight levelling to my Td5. Advice please |
Snatch Member Since: 30 Apr 2016 Location: Midlands Posts: 17 |
Hi
I have a 2000 90 .. I found the correct plug for the levelling switch behind the radio. It is a white plug with 6 spades .. 3 each side.. Your switch should have 6 male spades 3 each side.. I bought the rings and motors.. It's easy to do .. Wiring is behind headlights easy to find... Headlight adjuster plugs ..oblong and 3 pin. .. Hope this helps.. Forgot to mention fitted mine under radio as you suggested.. My plug was tucked away in dash but easy enough to find. |
9th Jun 2016 6:59pm |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 |
thanks for reply. I have the various plugs so that is the easy bit. Can source the other bits with not too much cost.
My main question was which levelling switch can I use as they all look the same but even seem to be different between a 90 and 110. |
9th Jun 2016 8:14pm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1749 |
Disco switch has different plug - as I found out thinking I had grabbed a bargain.
10th Jun 2016 5:15pm |
