Home > Tdi > Thrust bearing noise
jonnytatt
United Kingdom 1988 Defender 90 300 Tdi SW Nato Green
Last year or around 8k miles ago i had my clutch replaced for a Truckfix organic with a HD arm and new thrust etc.
Ive recently noticed the thrust bearing making a noise when the clutch is up. When i push the pedal in the noise disapears.
Its more noticable when the trucks cold.
Is this pretty standard as far as they go as there is not one problem with the clutch at all other than this and its not loud as such.
Ive had cars make the noise for years no issue. Just curious.
Tbh it could of done it since it was fitted but i took my straight pipe off last week so i can hear the radio..
Post #538316 7th Jun 2016 8:28pm
nickhodgson
Are you sure its the Thrust Bearing? What brand of bearing did you use?
Also what is a Truckfix organic? 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #544774 30th Jun 2016 9:03am
dorsetsmith
what is a Truckfix organic? = http://www.truckfixclutches.com/
Clutch Release Bearing i think he means
Post #544775 30th Jun 2016 9:09am
dailysleaze
That'll be the gearbox input bearing, which stops turning when you press the clutch. This is when the release bearing starts turning so if it was that then the noise would start when the pedal is down. Check the gearbox oil level
Post #558376 23rd Aug 2016 6:33pm
yostumpy
could be the spigot bush. Wink
Post #559525 28th Aug 2016 1:25pm
