![]() | Home > Tdi > Thrust bearing noise |
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
Are you sure its the Thrust Bearing? What brand of bearing did you use?
Also what is a Truckfix organic? 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
what is a Truckfix organic? = http://www.truckfixclutches.com/
Clutch Release Bearing i think he means |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
That'll be the gearbox input bearing, which stops turning when you press the clutch. This is when the release bearing starts turning so if it was that then the noise would start when the pedal is down. Check the gearbox oil level
yostumpy Member Since: 01 Aug 2010 Location: n/kent Posts: 327 ![]() |
could be the spigot bush.
