Home > Puma (Tdci) > EGR dying - does it really matter?
rick
Australia 2008 Defender 110 Puma 2.4 SW Stornoway Grey
I'm getting that chukka, chukka, chukka sound so i know the EGR valve is on its way out. But other than the red warning light being permanently on, is there any problem just letting it eventually die and just doing nothing about it (no blanking etc)? I get the impression the EGR isn't strictly necessary. Am I missing something? Cheers. 1998 RR HSE
2007 RRS TDV6
2008 Defender 110
2015 Discovery Sport
Post #538123 7th Jun 2016 8:20am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
Depends if it fails open or shut, if it fails shut then itd be better, also depends how strict your emissions testing is to whether your car would pass its annual check...
Post #538126 7th Jun 2016 8:28am
If it fails open you'll get all manner of running problems, if it fails shut the engine will run better. In the UK, the red light on the dash is an MOT test failure, however.
The current UK MOT test will not detect the the correct operation of the EGR, so if you have it disabled in a remap you will pass the MOT, but the MIL (warning light) being on will result in failure.
(On a TD5, in theory removing the EGR altogether may cause a failure, but only if the tester notices. On the TDCi the EGR is left physically in place so this risk doesn't exist).
I am not sure of the position down under, so cannot advise on in this respect.
Post #538129 7th Jun 2016 8:39am
