![]() | Home > Puma (Tdci) > Rear Seats |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2464 ![]() ![]() ![]() |
In a 110", last row removal takes more than 5 mins. Haven`t seen a 90 setup.
Bolts are ultra-tight, so you need good quality torxs. I recommend you spray them with WD40 or so before. Puma 110" SW ............................................................. Earth first. Other planets later |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 ![]() ![]() ![]() |
Took me longer than I expected - there are 4 torx into captive nots for the floor/seat support mountings which are a bit fiddly due to the cut outs in the carpet, and I think it was 2 torx and a threaded stud (with the nut on the wheel arch side) for the seat brackets. Getting the covers off the brackets with their pathetic plastic screw fittings is a delicate operation if you want to reuse them, and as MK says, everything else can be very tight, especially if the ends of the torx screws have corroded at all - break out the WD40, or similar.
Took me around 20 nins to do one seat (which gave me the extra space I needed) and I've left it as a 6 seater for the time being - I just taped over the various holes in the floor and seat box/wheel arch as a temporary measure rather than screwing all the torx back in...now where did I put all the fittings... ![]() 1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
Somewhere on here a search will show you the answer you require. Mike
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 ![]() ![]() ![]() |
Recommend you photo the springs, cos you'll forget how they go back in
![]() 110 HCPU Tipper |
ian964 Member Since: 01 Jan 2010 Location: Surrey Posts: 30 ![]() ![]() ![]() |
Yep, best part of an hour to take them out. I suspect it will be longer to put them back!
Not to mention the hernia in lifting them out of the back ![]() |
took me about an hour. had to grab a neighbour to help with a spanner on the nuts
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1866 ![]() ![]() ![]() |
Thanks for the advice all.
Thankfully I'd decided to leave them in place as 1 of the guys dropped out last minute. ![]() 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
