Home > Puma (Tdci) > Rear Seats |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2448 |
In a 110", last row removal takes more than 5 mins. Haven`t seen a 90 setup.
Bolts are ultra-tight, so you need good quality torxs. I recommend you spray them with WD40 or so before. Puma 110" SW ............................................................. Earth first. Other planets later |
9th Dec 2010 12:45pm |
gtveloce65 Member Since: 10 Nov 2008 Location: West Sussex Posts: 107 |
Took me longer than I expected - there are 4 torx into captive nots for the floor/seat support mountings which are a bit fiddly due to the cut outs in the carpet, and I think it was 2 torx and a threaded stud (with the nut on the wheel arch side) for the seat brackets. Getting the covers off the brackets with their pathetic plastic screw fittings is a delicate operation if you want to reuse them, and as MK says, everything else can be very tight, especially if the ends of the torx screws have corroded at all - break out the WD40, or similar.
Took me around 20 nins to do one seat (which gave me the extra space I needed) and I've left it as a 6 seater for the time being - I just taped over the various holes in the floor and seat box/wheel arch as a temporary measure rather than screwing all the torx back in...now where did I put all the fittings... 1953 80 1965 Alfa Romeo GT Veloce Sprint 1980 Fiat 124 Spider 2008 110xs |
9th Dec 2010 4:11pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5059 |
Somewhere on here a search will show you the answer you require. Mike
9th Dec 2010 5:36pm |
willy eckerslike Member Since: 15 Jun 2009 Location: North yorks Posts: 1789 |
Recommend you photo the springs, cos you'll forget how they go back in Original Member Pie n Pea Club.
110 HCPU Tipper |
9th Dec 2010 6:16pm |
ian964 Member Since: 01 Jan 2010 Location: Surrey Posts: 30 |
Yep, best part of an hour to take them out. I suspect it will be longer to put them back!
9th Dec 2010 7:47pm |
Lorryman100 Member Since: 01 Oct 2010 Location: Here Posts: 2686 |
Not to mention the hernia in lifting them out of the back |
9th Dec 2010 7:53pm |
BigMike Member Since: 13 Jul 2010 Location: Lancashire Posts: 2253 |
took me about an hour. had to grab a neighbour to help with a spanner on the nuts
9th Dec 2010 8:07pm |
Rosco Member Since: 03 Dec 2010 Location: Burntwood Posts: 1842 |
Thanks for the advice all.
Thankfully I'd decided to leave them in place as 1 of the guys dropped out last minute. 2007 - Stornoway Grey 90 XS SW - Gone 2002 - Black Discovery II - Gone 2014 - Montalcino Red 110 XS SW |
13th Dec 2010 11:35am |
