Home > Tdi > Diff oil or one shot in my wheel bearing.
jonnytatt
United Kingdom 1988 Defender 90 300 Tdi SW Nato Green
Hi its probably been covered im sorry if so but today i noticed under the rubber end cap at the hub wheel nut side a greyish thinner form of grease.
I renewed the swivels 5 months ago brand new kits both sides. Surely my swivel axle driveshaft seal hasnt gone so soon passing oil they was oem. Corteco.
I never renewed the stub axle seal. Im hoping its this and one shot is creeping through into my bearing. Now ive not got the best sense of smell how can i check if its one shot or actually diff oil passing through the swivel and down the stub axle and into the bearings.
Im aware its not a bad thing having ep90 lube my swivels and bearings but just want to check either way. Thanks. Thumbs Up
Post #536654 1st Jun 2016 8:09pm
jonnytatt
Must add pulled breather off i can blow through the pipe
Post #536655 1st Jun 2016 8:10pm
