- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Tdi > Diff oil or one shot in my wheel bearing. |
jonnytatt
Diff oil or one shot in my wheel bearing. | |
Hi its probably been covered im sorry if so but today i noticed under the rubber end cap at the hub wheel nut side a greyish thinner form of grease.
I renewed the swivels 5 months ago brand new kits both sides. Surely my swivel axle driveshaft seal hasnt gone so soon passing oil they was oem. Corteco.
I never renewed the stub axle seal. Im hoping its this and one shot is creeping through into my bearing. Now ive not got the best sense of smell how can i check if its one shot or actually diff oil passing through the swivel and down the stub axle and into the bearings.
Im aware its not a bad thing having ep90 lube my swivels and bearings but just want to check either way. Thanks.
1st Jun 2016 8:09pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
