Home > Puma (Tdci) > Richard Chassis on Puma |
bit new, lr only i'd say |
7th Dec 2010 7:22pm |
bartv Member Since: 03 Oct 2010 Location: Belgium Posts: 12 |
What does a LR chassis cost?
7th Dec 2010 7:27pm |
diesel_jim Member Since: 13 Oct 2008 Location: hiding Posts: 6102 |
Puma 90, from vin 9A onwards, LR015410 £2807.96 puma 110 " " " LR015411 £2794.64 (yup, it's longer, but cheaper!) Puma 110 HD (HD rear spring mounts, maybe some chassis plating) LR015409 £4094.93 puma 130 LR015412 £4094.93 (yup, same as a 110 HD) (this is LR prices, not Richards) |
8th Dec 2010 7:52am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5038 |
Other than a major accident...why would you bother Mike
8th Dec 2010 7:56am |
Major accident is the reason
http://defenderrebuildproject.blogspot.com/ |
8th Dec 2010 8:27am |
LCJ Member Since: 07 Sep 2009 Location: UK Posts: 201 |
Great project, thanks for the link. I'll watch that with interest. Good luck!
8th Dec 2010 9:43am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
if it's a right off how does the warranty stand anyway 2.4 90 XS
Zagato Site Supporter Member Since: 08 Jan 2011 Location: Billingshurst West Sussex Posts: 5013 |
It's incredible to see a Puma stripped down to the chassis and realise that the chassis and shell are almost the same after 50 years. Shame you cannot use the Richards chassis, they are very good. This is a pic of the same model as yours but it is a 1968 Station Wagon. I am just waiting for new doors. I envy you being able to buy all the parts you need off the shelf. It's the only thing that is holding up my rebuild. Good luck with your Puma rebuild and keep the pics coming Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated |
14th Jan 2011 4:41pm |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
Great pic of your restoration Zagato!
You could post some more, and keep us up to date in the off-topic section! I'd love to see process! Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
14th Jan 2011 8:11pm |
Zinke Member Since: 27 Jan 2009 Location: Scunthorpe Posts: 670 |
Dont marshland make them for land rover or something like that? Could be mistaken but ive sure ive read something alone those lines before? Im 100% sure they build the chassis the same as land rover though, the rails are 2 pressings welded down the middle. Not sure if im right but dont richardson's weld 4 pieces of flat together like the SWB series chassis used to be made?
Pete |
14th Jan 2011 8:20pm |
Yes lrmaniac I'll post some pics up for you Marsland no longer make Series LR chassis they are concentrating on Defender ones! |
15th Jan 2011 1:05pm |
TallPaul Member Since: 28 Aug 2007 Location: Nr Reading Posts: 270 |
Assuming its the same Zagato its worth reading the whole thread on the series2 forum
Marlands definitely make TDCi chassis now, would assume Land Rover manufacture their own though? Disco 3 gone but the memory of the bills remain... XS 110 Utility maybe one day..... (did they fix the quality yet?) |
16th Jan 2011 8:10pm |
defendertom Member Since: 20 Jan 2011 Location: gwent Posts: 29 |
i am building an svx on galv chassis. seems pretty easy until i have to start it. having problems. tried putting diesel stright to it but still wont fire. does anyone know why it would wind over and not start. there is diesel to the injectors.
20th Jan 2011 9:44am |
Hi defendertom and welcome to the forum I saw your post on welcome to defender2.net and see it is a Tdci engine in the project svx. Did the engine come with its ecu unit? Is there a 10AS unit? One reason for not starting is if the injectors are not coded to the ecu, maybe problems with the immobiliser in the 10AS unit? Could you post more info on the install of the Tdci power plant including the electronics side? Brian. |
20th Jan 2011 9:52am |
