Home > My Defender > 1989 Ninety CSW - Update: 8 cylinders
Page 8 of 20 <123 ... 789 ... 181920>
Procta
looking good that fan bracket, just need to wire tidy it then your laughing. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #637014 11th Jul 2017 8:45pm
trickster5000
United Kingdom 1989 Defender 90 300 Tdi CSW Arles Blue
Yeah I just chucked them on to see if it works, will obviously tie them up out of the way before taking it out for a spin Matt.
'89 90 CSW with a 3.5 V8 conversion (WIP) - http://www.defender2.net/forum/topic46809.html
Post #637015 11th Jul 2017 8:47pm
trickster5000
After what started out as a simple head gasket replacement nearly 2 months ago, we took her out for a spin around the block. The new engine seems to have a lot more poke than the old one and is quieter as well. It pulls very well with absolutely no smoke which is surprising for an engine that's been sat for a couple of years.
Overall extremely pleased, glad to have it back on the road and I can now focus on some mods Very Happy (oh and fix some of the new rattles Rolling Eyes ) Matt.
Post #637209 12th Jul 2017 8:43pm
L110CDL
Great outcome there with the engine Wink at least the "new " rattles should be easier to sort out Laughing Clayton.
Keeper.
Post #637393 13th Jul 2017 8:23pm
Procta
Normally the case, you don't always know what the story was with the old engine that was dropped in. It could have been bodged up and just dropped in to sell on. When you fixed the head gasket it, you may have un earthed more problems. When we did the head gasket on my rover metro last year, what should have been a simple fix as people said, turned into a major, major nightmare. I ended up un earthing problems after problems. At the end I just cut my losses and got shot, when it decided to jump into gear when I started the engine. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #637398 13th Jul 2017 8:30pm
trickster5000
Starting to wonder if the rattles aren't new but seem more audible now as the new engine is quieter and smoother. Turned out to be an absolute bargain, picked the engine up for £50 as spares or repairs, bit of a gamble but definitely paid off! Was also a pleasant surprise to find out the previous owner put new recon g/box and t/box on less than 4000 miles ago.
Got my side steps on this evening, passenger side was easy, used the sticky DIY rivnut tool thread to help with the rivnut bit. Driver's side however was an absolute sod to get on, managed to drop the fuel tank just enough to contort my hands through the tiny gap and somehow get a ring spanner on the nut. An unpleasant job to say the least but it's done now and they look great!
 Matt.
Post #637403 13th Jul 2017 8:43pm
L110CDL
Looks a good there with the steps Wink we all need some luck now and then, you certainly got that with the £50 Very Happy
Rolling with laughter you maybe right about the rattles now as you can hear them better Wink Clayton.
Keeper.
Post #637409 13th Jul 2017 9:18pm
trickster5000
Managed to get out for a few snaps this evening:
And this one I really like, reminds me of the gorgeous B+W photos they have in the first page of the Hanyes manual of, at the time, brand new 90s and 110s.
 Matt.
Post #637528 14th Jul 2017 6:32pm
They look great - very atmospheric Cool Darren
Post #637544 14th Jul 2017 7:48pm
Procta
looking well neat there now, that's not bad for 50 quid if the engine and gearbox is spot on! Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Post #637548 14th Jul 2017 8:24pm
L110CDL
Great pics Thumbs Up Clayton.
Keeper.
Post #637875 16th Jul 2017 8:19pm
trickster5000
Thanks Smile
Had a fantastic day at the Kelmarsh LR show. Always enjoy a good look around the 2nd hand stalls for little gems, this time I managed to pick up a Td5 clutch assembly with a clutch spring assist so hoping for a lighter clutch. Got a new gear lever and knob with proper threads for the knob to screw into so it doesn't twist and turn. Picked up one of those pesky seat recliner lever caps, had one missing for ages but didn't want to pay a fiver for a new one.
Finally I got a pair of retro heritage badges for a bargain of £25! Admittedly they're not Artmin but at less than half the price I'm extremely pleased!
I opted for the safer option of putting rivets in the holes and sticking the badge on with double sided tape.
Removing the green oval and 3D lettering I applied last year was a bit of a pain - I was very worried about damaging the paintwork and in the end I did end up pulling a bit of paint off with the badge but it will be covered by the new one.
 Matt.
Post #638871 21st Jul 2017 8:33pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
Those badges do look very smart Thumbs Up 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #638883 21st Jul 2017 9:01pm
Van Whalen
Australia
Badges look great! I've just ordered the same/similar for my 90. Thumbs Up
Post #638949 22nd Jul 2017 6:00am
trickster5000
Thanks I'm really pleased with them.
Today I swapped the clutch pedal assembly, or at least tried. Swapping the pedals was surprisingly easy - 6 bolts and then a bit of wiggling to squeeze it through the bulkhead.
The problem came when we tried to bleed it. It sort of dribbled out a bit but no bubbles, no pressure and the pedal had no resistance. After a while trying to bleed with no change, we came to the conclusion that the master cylinder is knackered.
Is this a reasonable conclusion? Can I just swap over my old master cylinder?
Either way I'm going to have to remove the entire pedal assembly again... Matt.
Post #639250 23rd Jul 2017 8:06pm
