Home > Puma (Tdci) > Engine Control Module/Air Con Leak
davidpalfreyman
2009 Defender 110 Puma 2.4 CSW Alpine White
Hello,
I have a leak in the air conditioner evaporator. I have removed the dashboard and now have to remove the unit containing the heater and air conditoner evaporator.
It seems that I have to remove the Engine Control Module (ECM) to disconnect the heater pipes inside the engine compartment.
If I remove the ECM, does it need any computerised tweaking after refitting?
Is there any way of removing the heater/air conditioner core without touching the ECM?
Thanks in advance for any tips or ideas.
If anyone needs any dashboarrrd removal tips, I am ready as it is all stil fresh in my mind
David (2009 Puma) in Tanzania
Post #535881 30th May 2016 4:05pm
nickhodgson
I have done the exact process before and yes you have to remove the computer box (ECU). I disconnected the battery before I removed the connectors on the ECU and it all went back fine. At first it did not start but when I connected up the speedo cluster it started fine. I did not have to use any diagnostic stuff to get it going.
The aircon thermostat or de ice switch has been revised so make sure you are fitting the latest part number.
On my aircon I believe the de ice switch failed leading to icing on the evaporator and eventually evaporator failure.
Nick 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #536022 31st May 2016 6:13am
davidpalfreyman
Nick,
Thanks so much. I will follow your advice.
David
Post #536061 31st May 2016 11:17am
davidpalfreyman
Nick,
It worked exactly as you said!!
Thanks so much.
David
Post #539191 10th Jun 2016 6:38pm
ronwong
2012 Defender 110 Puma 2.2 SW Orkney Grey
Hi, was it a big job? The whole dash have to come off? And the ecu in the engine bay?
Post #547458 10th Jul 2016 2:01am
davidpalfreyman
It was a big job but not as bad as I thought. Whole dash off - sounds worse than it is and the ECU was a doddle.
If you want to try it, I wlii be happy to give you any tips from my limited experience
David
Post #547590 10th Jul 2016 7:04pm
GregK Myanmar
2010 Defender 110 Puma 2.4 SW Stornoway Grey
Hi, I have an air con leak that has got to the stage that if I re gas it will will only work for 2 weeks now.
We believe it is the evaporator which will have a small hole. I want to get the part but when I look in the parts catalogues it is not shown in any schematic. I have found so far.
So I need to know the part number for the evaporator.
In the workshop manual it shows a picture of the heater unit without the evaporator and says.
"The heater assembly is mounted behind the instrument panel on the vehicle center line. The heater assembly contains
an aluminum heater matrix and a diffuser plate to deliver the required air temperature into the cabin. If the vehicle is
fitted with A/C, the A/C evaporator replaces the diffuser plate in the heater assembly."
In the parts catalogue I can only find the heater matrix part no. LR020952
Reciever dryer is JRJ000020
Expansions valve is JQD500070
Any ideas or help appreciated. 2010 Defender 110 Puma 2.4 TDCI.
Post #596968 28th Jan 2017 3:37pm
davidpalfreyman
Greg,
I removed the evaporator/heater assembly and modified an evaporator from a Toyota.
The only part that Land Rover supply, as I understand, is a complete evaporator/ assembly unit which is very expensive an virtually impossible to get here in Tanzania
It has worked well now for 7/8 months.
If you need any more info, I will be glad to help
David
Post #596974 28th Jan 2017 3:54pm
GregK Myanmar
David
You had to do that for a Puma TDCI?
What is the part number for the complete unit?
I am getting scared now as no one in the posts above has metioned it as being a super expensive unfindable part.
Plenty of toyota s here though. 2010 Defender 110 Puma 2.4 TDCI.
Post #596992 28th Jan 2017 4:41pm
davidpalfreyman
Greg,
I never got the part number, sorry. You have to order the whole evaporator and heater assembly in it's black plastic box that you can see at the bottom of the dashboard. That is what the parts dept here told me. They would have to order it from UK. The modification using a second hand Toyota evaporator was not too difficult and very cheap in comparison.
David
Post #597028 28th Jan 2017 6:58pm
GregK Myanmar
From what is being said above it looks like it maybe I have to buy all this?
Part no. LR036308 for LHD. £458.46 plus
http://www.brit-car.co.uk/product.php/1881...er_2007_on
And the air con in these cars is Censored anyway it has never worked well for last few years. The controller is just a stupid design and even if you change it it still freezes up. 2010 Defender 110 Puma 2.4 TDCI.
Post #597166 29th Jan 2017 6:04am
davidpalfreyman
Greg,
Mine also used to freeze up but since fitting the Toyota evaporator, it has not done it again. That could be because it was full of dirt, dust, etc.
It cost me about £50 inc fitting and gas!! Did all the dashboard removal etc myself
David
Post #597546 30th Jan 2017 7:03am
GregK Myanmar
David, Thanks for your help. Do you know the part no. for the toyota one or what car model it was from?
I should be able to do it all here. I have taken the dash out before to change the air con controller.
Greg 2010 Defender 110 Puma 2.4 TDCI.
Post #598007 31st Jan 2017 1:25pm
davidpalfreyman
Sorry, I don't have the party number or the model of Toyota. I removed it, gave it to the Air Con man and he went to find one that was a similar size.
Wish I could help. After fitting the new one I drove the car for a couple of weeks without the dash to make sure it was ok.
Hope you succeed
David
Post #598056 31st Jan 2017 5:11pm
GregK Myanmar
Ok I have taken out the whole dash and the unit and confirmed that the evaporator is leaking. I have checked with an air con repairer here and we could not find one that would replace it. It is relatively small.
That guys says there are about 10 of these Pumas in Yangon and all have the same problem. He is searching in China for a replacement. Says they only last about 5 or 6 years.
Mine had several small leaks and one major which was the final straw.
So mine had several fine leaks and one big one.
So it looks like every six years we will have to buy a whole new unit for over $500 US. Thats brilliant design Landrover.
I also took photos along the way and will make a dash removal document soon. 2010 Defender 110 Puma 2.4 TDCI.
Post #601674 14th Feb 2017 6:38am
