Home > Maintenance & Modifications > AC and speedo problem -limp mode
Kong
Hong Kong 2010 Defender 110 Puma 2.4 SW Aintree Green
My 2010 puma has a AC problem. Whenever I turned on the AC, the engine went into limp mode and the speedo dropped to zero. Even if I off the air con, the vehicle remained in limp mode and same to the dead speedo. The situation will be back to normal after I switched off the ignition several times, the speedo become normal and has it reading perfectly. The cycle will repeat if I turned on the AC.
Please help....
Post #535587 29th May 2016 8:52am
Kong
By the way, there is no cold wind coming from the AC!!
Post #535603 29th May 2016 10:30am
Check wiring for any possibly damage, or chafing.
Post #535617 29th May 2016 11:56am
