Home > Off Topic > Trailer Wheels, Axels & Hubs...anyone an expert?
MartinK
I have a K Trailer built in 2004 (I bought it new). The manufacturer has changed guises several times, and when I phoned they were quite unable to help me over the phone.
It looks like this:
The trailer tyres are getting past their best, one has a slow puncture. They're 10".
So I was thinking of replacing them, with wheels of a larger diameter so the trailer sits flatter (the high back end of the Defender means that the trailer slopes backwards quite a bit...
So - 12" or 13" wheels seem more common (13" seems most common).
My hubs are 4" centres I think, but the bolt holes are only 3/8. Plus the wheels have an odd cut-out to allow the grease nipple:
The suspension appears to be an axle beam like the ones at Indespension... http://www.indespension.co.uk/58-axle-beams
Piccie under:
So... I think the best route would be to change the hubs as well? Something more beefy with a "proper" bolt size?
I'm not looking to increase the weight limit of the trailer, just level it out, and increase the road manners with larger wheels,
Anyone help??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #535176 27th May 2016 2:28pm
muddybaldboy
Wales 1999 Defender 110 Td5 HT Chawton White
I've got a pair of new, unused 750kg indespension units which have hubs for land rover wheels which I bought for a project which I changed my mind about. Include mounting plates. Is that what you had in mind? He who dies with the most toys...wins!
Post #535179 27th May 2016 2:55pm
MartinK
muddybaldboy
I had thought that! But the axle on mine is a full length beam axle so it's harder to swap for "normal" axle plates (without welding I think)
I think I just need hubs, and wheels... Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #535184 27th May 2016 3:30pm
DAZ110
United Kingdom 2013 Defender 90 Puma 2.2 XS CSW Barolo Black
Classic Mini 12'' wheels might fit?
Post #535198 27th May 2016 4:53pm
Romadog
You need to check the PCD on your current rims.
Then the offset if any so tyres dont rub side of trailer.
Larger diameter may cause issue with mudguards????
Look on this website. If you give them a call they will help you.
http://www.ate-uk.com/wheels-tyres-mudguar...blies.html
Post #535215 27th May 2016 5:26pm
muddybaldboy
MartinK wrote:
muddybaldboy
No worries.
As Romadog said, wheel arches will need to go in favour of bigger ones Thumbs Up He who dies with the most toys...wins!
Post #535234 27th May 2016 6:55pm
MartinK
I'm feeling that I need new hubs, and new wheels.
The question is whether I can use different hubs on the same axels...??? Defender "Puma" 2.4 110 County Utility (possibly the last of the 2.4's)
Post #535626 29th May 2016 1:15pm
Hifonics
2013 Defender 110 Puma 2.2 USW Corris Grey
When I priced it all up after wrecking a wheel and hub it wasnt much more to replace it all. I got it all from Indespension and their service was very good and pretty much the cheapest.
Post #535864 30th May 2016 1:38pm
