Home > Td5 > [HELP] Easy access to permanent live on 2000 TD5 90
jrharte
United Kingdom 2000 Defender 90 Td5 X-Tech LE Zambezi Silver
Hey guys,
First time defender owner (just purchased from this forum too!)
I've got a 2000 TD5 90 and I'm looking for access to a permanent live as I want to hard wire one of those little tracker boxes in.
P.S. Are there any online manuals / guides? I was gonna just start unscrewing the dash and having a look but sure I can't find any info on the wiring colours anywhere either.
Post #534615 25th May 2016 5:16pm
Lancerdoc999
depends where you are going to put the tracker I suppose. You can run a wire from the battery to any location. Try and hide it. I assume the ignition has perm 12v for dash installation. starter motor/alternator. Not sure there is anything in the rear
Post #534625 25th May 2016 6:06pm
miker
Purple wire in the load area on the rear light loom is perm live. Drivers seat box has supplies. Passenger seatbox has the battery! Engine bay - starter.
Dash: Radio has a permy feed. Interior lights too.
That should give you a bit to go on!
Post #534656 25th May 2016 7:29pm
jrharte
Thanks guys.
So I guess from these pictures that the purple is perm live and the red going into the orange plug is only live when ignition is on?
Post #535222 27th May 2016 6:02pm
jrharte
Yep permanent 12v as confirmed here by Martin also: http://www.defender2.net/forum/post533333.html
Thanks Miker.
I also found this: http://www.dimebank.com/LucasColours.html
If it's of use to anyone.
Post #535225 27th May 2016 6:25pm
