![]() | Home > Td5 > [HELP] Easy access to permanent live on 2000 TD5 90 |
Lancerdoc999 Member Since: 10 Apr 2016 Location: South Wales Posts: 205 ![]() ![]() |
depends where you are going to put the tracker I suppose. You can run a wire from the battery to any location. Try and hide it. I assume the ignition has perm 12v for dash installation. starter motor/alternator. Not sure there is anything in the rear
miker Member Since: 13 Sep 2015 Location: Surrey Posts: 1772 ![]() ![]() ![]() |
Purple wire in the load area on the rear light loom is perm live. Drivers seat box has supplies. Passenger seatbox has the battery! Engine bay - starter.
Dash: Radio has a permy feed. Interior lights too. That should give you a bit to go on! |
jrharte Member Since: 08 May 2016 Location: Newry Posts: 20 ![]() ![]() ![]() |
Thanks guys.
So I guess from these pictures that the purple is perm live and the red going into the orange plug is only live when ignition is on? ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
Yep permanent 12v as confirmed here by Martin also: http://www.defender2.net/forum/post533333.html
Thanks Miker. I also found this: http://www.dimebank.com/LucasColours.html If it's of use to anyone. |
