Home > For Sale & Wanted > [For Sale] 2007 XS seat covers/head rests £50 as removed
TACK
2no front seat covers (black rack) complete with head rests as removed from my 2007 XS defender. Good condition. One seat has a split down the side, not all the way through, put it on the cubby box side and it will not be seen. Collection RM20 (dartford bridge)
Post #534135 23rd May 2016 9:21pm
Stiff1
Hi, out of interest, how difficult were they to remove, I have a faulty heater on my drivers seat, any tips appreciated?
Post #534170 23rd May 2016 11:11pm
Christian1402
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Indus Silver
Hi,
What would the price posted be please? I'm currently out the country but would be interested if
You'd post?
Cheers, Christian
Post #534235 24th May 2016 9:52am
TACK
Easier for me to remove, as I was not concerned about damaging the foam. My seats covers (2007 puma) (backs) were connected via small metal rigs, crimped to a metal rail which is set within the foam. You would need to cut these/open them up to lift the cover up. These can simply be replaced by cables ties, or reused. The pad is then stuck to the foam and easily removed without damaging the foam. You might only need to remove 1 ring each side, roll the cover up a few inches and gain enough access to do it without removing the whole cover. That’s what I would have a go at first of all.
The base is simpler in some respect, cover off and carefully remove the heater pad from the foam. Although to get the new cable through the bottom of the seat, you might have to separate the foam from the metal base. Can be done, and probably the only way. Maybe a coat hanger to feed it through might work.
Do you know which one has stopped working, base or back?
Post #534248 24th May 2016 10:32am
TACK
Christian1402 wrote:
Hi,
You'd post?
Cheers, Christian
Christian, can I have or PM me your postcode so I can get a quote.
thanks TACK
Post #534262 24th May 2016 11:22am
TACK
Christian pm sent
For others whom many enquirer, postage is roughly £15. But can quote based on postcode Thumbs Up
Post #534328 24th May 2016 6:48pm
Stiff1
Thanks for that, not sure which one is the problem as neither work.
I presume they are wired in series, when one goes they both do. If not, then my problem may lay elsewhere ?
Any thoughts?
Post #534355 24th May 2016 8:00pm
TACK
Sold Thumbs Up
Independently wired. I would check elsewhere first stiff. Check the cables for damage, or maybe the switch has packed up?
Post #534931 26th May 2016 6:34pm
TACK
Bump, Still for sale
Post #543810 27th Jun 2016 9:44am
TACK
Bump, reduced to £50
Post #549899 20th Jul 2016 5:14am
TACK
Bump
Post #565240 19th Sep 2016 9:09pm
TACK
Bump, all packaged ready for posting
Post #567983 1st Oct 2016 8:33am
Woody3
United Kingdom 1989 Defender 90 200 Tdi HT Bronze Green
Did the shape of the seat/foam alter when the Puma came out? Wondering whether these will fit my pre Puma vinyl seats or not...
Post #568016 1st Oct 2016 1:06pm
T140
Scotland 2007 Defender 90 Td5 HT Zambezi Silver
PM sent nobody is perfect but being Scottish is a start
Post #568022 1st Oct 2016 1:46pm
TACK
Sorry I can't answer that question Neutral
Post #568025 1st Oct 2016 2:45pm
