Home > For Sale & Wanted > [For Sale] 2007 XS seat covers/head rests £50 as removed |
TACK Member Since: 26 Apr 2009 Location: Essex Posts: 1045 |
2no front seat covers (black rack) complete with head rests as removed from my 2007 XS defender. Good condition. One seat has a split down the side, not all the way through, put it on the cubby box side and it will not be seen. Collection RM20 (dartford bridge)
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Last edited by TACK on 20th Jul 2016 5:14am. Edited 1 time in total |
23rd May 2016 9:21pm |
Christian1402 Member Since: 17 Feb 2016 Location: Cumbria Posts: 214 |
Hi,
What would the price posted be please? I'm currently out the country but would be interested if You'd post? Cheers, Christian |
24th May 2016 9:52am |
Easier for me to remove, as I was not concerned about damaging the foam. My seats covers (2007 puma) (backs) were connected via small metal rigs, crimped to a metal rail which is set within the foam. You would need to cut these/open them up to lift the cover up. These can simply be replaced by cables ties, or reused. The pad is then stuck to the foam and easily removed without damaging the foam. You might only need to remove 1 ring each side, roll the cover up a few inches and gain enough access to do it without removing the whole cover. That’s what I would have a go at first of all. The base is simpler in some respect, cover off and carefully remove the heater pad from the foam. Although to get the new cable through the bottom of the seat, you might have to separate the foam from the metal base. Can be done, and probably the only way. Maybe a coat hanger to feed it through might work. Do you know which one has stopped working, base or back? |
24th May 2016 10:32am |
Christian, can I have or PM me your postcode so I can get a quote. thanks TACK |
24th May 2016 11:22am |
Christian pm sent
For others whom many enquirer, postage is roughly £15. But can quote based on postcode |
24th May 2016 6:48pm |
Stiff1 Member Since: 09 Dec 2014 Location: Cornwall Posts: 595 |
Thanks for that, not sure which one is the problem as neither work.
I presume they are wired in series, when one goes they both do. If not, then my problem may lay elsewhere ? Any thoughts? |
24th May 2016 8:00pm |
Sold
Independently wired. I would check elsewhere first stiff. Check the cables for damage, or maybe the switch has packed up? |
26th May 2016 6:34pm |
Bump, Still for sale
27th Jun 2016 9:44am |
Bump, reduced to £50
20th Jul 2016 5:14am |
Bump
19th Sep 2016 9:09pm |
Bump, all packaged ready for posting
1st Oct 2016 8:33am |
Woody3 Member Since: 13 Jan 2010 Location: Derbyshire Posts: 415 |
Did the shape of the seat/foam alter when the Puma came out? Wondering whether these will fit my pre Puma vinyl seats or not...
1st Oct 2016 1:06pm |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 173 |
PM sent nobody is perfect but being Scottish is a start
1st Oct 2016 1:46pm |
Sorry I can't answer that question |
1st Oct 2016 2:45pm |
