Home > Wheels & Tyres > BFG AT 235/75/16 vs 265/75/16
Page 2 of 3 <123>
camelman
The speedos do read bit higher but fitting 285's brings it bang on with the GPS.
The odometer tends to be fairly much spot on with 235s but ends up reading about 4% lower than actual with the 285s.
As a result 300miles on the odometer is actually 312 miles on the road..
Post #532767 18th May 2016 8:55pm
Pickles
No fouling/hitting on anything then, with 265/75,...nothing on full lock etc?
What about "tracking" on a straight smooth road,...no wandering, harder to keep in a straight line without steering wheel correction etc?
I'm not due for tyres, but I do like the wider/"squatter" look, so all this is good info for me.
Thanks, Pickles.
Post #532834 18th May 2016 11:22pm
jaygti
United Kingdom 2002 Defender 90 Td5 HT Epsom Green
It depends on how well adjusted the lock stops are in the first place.
If they were spot on for 235/85 then the tyres will rub with 265/75 on full lock.
It doesn't matter if the do though, as it's dead easy to adjust.
As for tracking I noticed no difference between 235 and 265, I did however notice a difference when going up to 285/75 as the tyres are taller. It's only minor though and you forget about it after a few days. 2002 td5 90 county hardtop
Post #532857 19th May 2016 6:16am
stevie
I'm thinking of changing my 235 85 16 mtr,s for some all terrain ko2. If I have 265 75 16 will the height of my vehicle remain the same? I ask as it only just fits in the garage at the moment and if 265 75 16 lift it any higher then It may not fit under the door.
I haven't used bfg all terrains for a while but I presume they are a lot quieter than the Goodyear mtr that I currently have on? I'm planning a long road trip this summer and don't fancy listening to the mtr's on the motorway.
Post #534639 25th May 2016 7:44pm
jaygti
Yes it should be identical in height, in fact 265/75 will be 804mm in diameter, and the 235/85 will be 806mm.
So slightly lower😀😀 2002 td5 90 county hardtop
Post #534645 25th May 2016 8:02pm
Nick666
United Kingdom 1986 Defender 90 2.5 n/a Diesel SW Yellow
On this same (ish) topic, anyone know if 235/85s will fit (widthways) on 16x8 mods or are they too narrow?
Post #541128 17th Jun 2016 9:33pm
jaygti
Yes they will be fine. It's the upper limit but it'll be ok. 2002 td5 90 county hardtop
Post #541135 17th Jun 2016 9:42pm
Tommo
United Kingdom 2006 Defender 90 Td5 Black LE Java Black
I have a pending dilemma.
Currently run 235/75s Goodrich A/T and have a brand new one as spare.
However, like the look of 265s but would have to replace all 5(£££) if I went for them. Current 235s are the older version of the A/T so are these still available and if so I only need to replace 4!
solutions to my dilemma welcome!
Tommo
Post #554032 6th Aug 2016 11:34am
agentmulder
Kuwait
So slightly lower😀😀
Assuming new 265s, and the tread wear on the 235s is greater than 1mm - it'll actually be higher. Solved the bowel problem, working on the consonants...
Post #554042 6th Aug 2016 12:31pm
monsoon
1990 Defender 90 2.5 n/a Diesel SW Arles Blue
can i use 235x85x16 on my defender 90 if i use spacers the alloys came off a disco
Post #555758 13th Aug 2016 4:11pm
Bluest
That's the standard tyre size on my Puma, so should fit, no spacers needed.
Post #555780 13th Aug 2016 6:12pm
When I built my 110 I had two sets of tyres (255/85 BFG MT's for playing, and 235/86 General TT's for road), the TT's were pretty good really, handling was nice.
Fast forward to them getting worn, so I up-sized to 265/75 BFG ATs. I preferred the look of the 265's,but every tramline in the road they would follow, and handling for some reason always seemed a little "strange" and I also have a Mantec steering guard fitted (standard LR "option" part) and they rubbed on the corner of it.
Fast forward again to the 265's being worn, I dropped back to 235/85 Goodyear MTR. The handling is now perfect, no rubbing on full lock, cross country performance is the same and I don't get muddy side windows anymore.
Post #555831 13th Aug 2016 9:45pm
monsoon
235/75/16 or 235/85/16
Still not sure,
if i fit 235/85/16 on my 1989 defender 90 which has disco wheels and 30 mm spacers will the speedo be correct ,
also would there be no ajustment needed to the defender,
Please could someone give me a just the basic answer.
Monsoon
Post #555887 14th Aug 2016 10:00am
Retroanaconda
Yes they will fit, you won't need the spacers so it's purely an aesthetic choice or if you need the extra steering lock.
Speedo may or may not be out, it depends what drive gear is in there currently. Fit them and then check it against a GPS, if it's out then you can change the drive gear.
Post #555890 14th Aug 2016 10:05am
monsoon
235x85,16
i would like to put spacers on my defender 90 as the disco wheels are tight and you cannot get the centres in without them.
if i use a 235/85,16 will everything be in sink i;e speedo and no rubbing.
Monsoon
Post #555896 14th Aug 2016 10:26am
Page 2 of 3 <123>
