Home > Puma (Tdci) > Rear indicators stopped working
kjmeijer
Netherlands 2016 Defender 110 Other SW Galway Green
This morning I noticed that my rear indicators/hazard on both sides do not work anymore. I have checked fuses but as the front indicators work fine I suspect something else.
A few years ago I fitted led indicators and an other relais but I never had problems.
Any ideas? 2021 Defender 110 D300 HSE
Post #532395 17th May 2016 3:54pm
dorsetsmith
( earthing ) test with multimeter at indicators , is your trailer socket work OK i.e. indicators
Post #532399 17th May 2016 4:02pm
^^^^ I'd second that too, even more likely if there has been any recent clutch change or any drivetrain work completed.
Earth strap for rear hardness is on the back of the transfer box and for once is a single bolt with easy access.
It's likely to be the issue I I hope.
Remove, clean, re-fit and tighten.
Post #532401 17th May 2016 4:07pm
kjmeijer
That is useful information because I had a lot of trouble with the dealer the last few weeks. The truck has been there three times for oil leakage on the transfer box and the clutch plates where also renewed.
Last friday a new oil leakage occured and next thursday the car is of to the dealer again.
Never ending story..... 2021 Defender 110 D300 HSE
Post #532407 17th May 2016 4:13pm
They'd un-bolt the earth on there to remove, they did on mine too and after I had lighting issues.
It wasn't tightened properly and most importantly it was dirty.
I don't know if you do or not but if like me you have LED's they are even more sensitive to voltage losses, fluctuations and earthing issues.
Post #532413 17th May 2016 4:44pm
