Home > Puma (Tdci) > Rear indicators stopped working |
( earthing ) test with multimeter at indicators , is your trailer socket work OK i.e. indicators
17th May 2016 4:02pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20443 |
^^^^ I'd second that too, even more likely if there has been any recent clutch change or any drivetrain work completed.
Earth strap for rear hardness is on the back of the transfer box and for once is a single bolt with easy access. It's likely to be the issue I I hope. Remove, clean, re-fit and tighten. |
17th May 2016 4:07pm |
kjmeijer Member Since: 09 Apr 2012 Location: Netherlands Posts: 84 |
That is useful information because I had a lot of trouble with the dealer the last few weeks. The truck has been there three times for oil leakage on the transfer box and the clutch plates where also renewed.
Last friday a new oil leakage occured and next thursday the car is of to the dealer again. Never ending story..... 2021 Defender 110 D300 HSE |
17th May 2016 4:13pm |
They'd un-bolt the earth on there to remove, they did on mine too and after I had lighting issues.
It wasn't tightened properly and most importantly it was dirty. I don't know if you do or not but if like me you have LED's they are even more sensitive to voltage losses, fluctuations and earthing issues. |
17th May 2016 4:44pm |
