Home > Puma (Tdci) > KPH to MPH instrument cluster display
Spartan
Is there a way to change the KPH to MPH on the instrument cluster display? Is this a DIY project or does it have to be done at the dealer? Can I send my cluster to have this done?
Post #532207 17th May 2016 3:23am
agentmulder
Kuwait
If I want the opposite, can Spartan and I simply swap binnacles?
Rolling with laughter
But seriously? Solved the bowel problem, working on the consonants...
Post #532208 17th May 2016 4:09am
Hi spartan
Alive tuning make decals/ overlays from puma dash boards, if you can use a screw driver they are pretty easy to fit. Take binnacle out, take off front, remove needles, swap decal over and put back together again
Mulder - if you swap out the binnacle you need the dealer to pair the binnacle with the ecu and 10as units
I know, I've imported a defender into the uk and swapped from kph to mph/kph, odometer is ok with km
Interesting, European spec cars don't have mph
Post #532209 17th May 2016 5:31am
Spartan
BPMan,
I failed to mention that I already replaced the decal to MPH I even purchased a brand new instrument cluster but when installed it has a few error lights that light up so I have been using the KPH. I can live with it but was wondering if there was an easy way to change it.
Are new clusters plug and play? Mine certainly did not.
Post #532339 17th May 2016 1:43pm
Tjhappel
United States 2010 Defender 110 Puma 2.4 XS CSW Santorini Black
I'd love to know also, I spend 50% of my time in the US with a puma and it would just be easier for me. Anyone with any ideas please pm me.
Post #533602 22nd May 2016 5:38am
