![]() | Home > Puma (Tdci) > KPH to MPH instrument cluster display |
agentmulder Member Since: 16 Apr 2016 Location: Outer Space Posts: 1324 ![]() ![]() |
If I want the opposite, can Spartan and I simply swap binnacles?
![]() But seriously? Solved the bowel problem, working on the consonants... |
Hi spartan
Alive tuning make decals/ overlays from puma dash boards, if you can use a screw driver they are pretty easy to fit. Take binnacle out, take off front, remove needles, swap decal over and put back together again Mulder - if you swap out the binnacle you need the dealer to pair the binnacle with the ecu and 10as units I know, I've imported a defender into the uk and swapped from kph to mph/kph, odometer is ok with km Interesting, European spec cars don't have mph |
Spartan Member Since: 24 May 2014 Location: Internet Posts: 8 ![]() |
BPMan,
I failed to mention that I already replaced the decal to MPH I even purchased a brand new instrument cluster but when installed it has a few error lights that light up so I have been using the KPH. I can live with it but was wondering if there was an easy way to change it. Are new clusters plug and play? Mine certainly did not. Cheers |
Tjhappel Member Since: 08 Aug 2012 Location: Southern California Posts: 32 ![]() ![]() ![]() |
I'd love to know also, I spend 50% of my time in the US with a puma and it would just be easier for me. Anyone with any ideas please pm me.
