![]() | Home > Defender Celebration Series & Classic Works > Defender 110 Adventure |
CR Member Since: 28 Jan 2010 Location: Ireland Posts: 947 ![]() ![]() ![]() |
they deffo look better in black
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 ![]() |
Just installed & wired up front roof rack lights & rear work light
Thanks Andy - mcma1 Just need to solve flicker on RR lights ❗️ ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 2020 P300 HSE |
Gatecrasher Member Since: 19 Mar 2016 Location: Surrey Posts: 76 ![]() ![]() ![]() |
Hi PJB,
Really like your roof lights, apologies if daft question, what make are those and approx cost if you don't mind me asking? I see you have installed switches for them, have you also wired them to come on with your high beam and reversing light automatically as well as independently with the switches? Just enquiringly as looking at doing similar mod, many thanks |
Hi
Not a silly question I bought them from mcma1 they are S/H JW Speaker TS 4000 LED Lights. Lets just say they were not cheap s/h ![]() ![]() |
Don't worry your secret is safe on here
![]() And how did you wire them up? Was it just through the two dash switches? and/ or through the high beam/ reverse function? as I was wandering if both of these are an option. Thanks again. |
Hi Gatecrasher
I decided to wire up so I can put them on independently of anything else, like for example when I need light trying to level the caravan & put the awning up when its ![]() I obviously have standard reversing lights & initially wired the back work light to come on with reverse lights, but decided I often want to use the work light when not in reverse so hence the above wiring. Tim at mobile centre I'm sure could sort out a wiring system that would allow both, but a long way beyond my wiring abilities ! Cheers Paul 2020 P300 HSE |
Have ordered some of these to replace the Spotlight 2 switches
![]() ![]() Click image to enlarge Sourced from Aus as I could not find anything in the uk - Bet I will find them now Not sure how good they will look but like the idea. 2020 P300 HSE |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7916 ![]() ![]() ![]() |
Having just read a thread about a stolen 110, please be careful it isn't driven off whilst you faffing with the caravan!
Personally I would have wired them to work with the ignition off then at least you don't have to have the keys in the unattended vehicle? Am I being too paranoid? Just food for thought ![]() MY2012 110 2.2TDCi XS SW Orkney Grey - http://www.defender2.net/forum/topic43410.html MY1990 110 200TDi SW beautifully faded Portofino Red - https://www.defender2.net/forum/post743641.html#743641 MY1984 90 V8 Slate Grey - https://www.defender2.net/forum/post744557.html#744557 Instagram @suffolk_rovers |
Don't worry everytime I do anything to her I become even more paranoid
Gotcha, many thanks, like the new switches too
stravaig Member Since: 08 Feb 2011 Location: Perth Posts: 57 ![]() ![]() ![]() |
Does anyone know how many adventure 110 s were made in each of the colours????
I think there were 600 UK Models
I was told when I bought mine 200 in each colour 100 in 90 100 in 110 in each colour But that might just be dealer simple arithmetic 2020 P300 HSE |
I believe some cars overran the end of production date and ended up as 2016 cars does anyone know how many of those there are ?
Thank you for your reply |
